Author Subject: Bent Valve Syndrome VID
puglover Banned!
Well ive got my engine running and i think its got the dreaded tap. Sad
Thing is i cant remember what a normal engine sounds like its been so long and cant tell if its loud injectors or what but something isn't sounding right Dry
It increases in speed as the engine revs but doesn't really get any louder. Ive disconnected each injector in turn and that hasn't made any difference.
The timing hasn't slipped either and i dont think Nick at lynx would have cocked it up when he put it together No
One for carl this but would i still be able to hear it if i just crank the engine or is it not fast enough?? Ive done this and it sounds fine.
The sound is most noticeable at idle but im sure its not anything else as it defo seems to come from the fuel rail area/head. It doesn't sound like a deep tap but its not really a tick either.
Oil pressure to the head is good. Yes
Ive tried the screwdriver test and cannot locate the sound at all Sad
Bit gutted really the head was from James R who got it from pug racing aka miles and had some 3 angle valve seats cut at QEP so everyone involved are top blokes.
Will have to get the car taken to Carl i think to sort it out which is going to cost me an arm and a leg. Sad
Oh well thats life i guess.
Posted 10th Oct 2009 at 02:00
Sure it's not just because the lifters aren't filled up/freed off properly?
Posted 9th Oct 2009 at 02:12
puglover Banned!
i thought this but its been running for 20 minutes now Sad
Posted 9th Oct 2009 at 02:17
often does take some time, is that 20 minutes at idle though? you'll not get that much pressure at idle.
could be a noisy bas**rd injector.
whip the cam covers off and see if any of the tappets are soft, they should be pumped up and have no clearance to the cam.
Posted 9th Oct 2009 at 02:21
puglover Banned!
its been revved to about 3.5k max on and off. Oil has been up to temp twice now.
its on 10/40 magnatech
I was hoping it was an injector but ive disconnected each injector in turn and this didnt change anything apart from my engine nearly dieing Sad
same with coil packs
Posted 9th Oct 2009 at 02:25
fletch
Track Head
How loud are we talking?
Using a decent oil I take it?
Check the plugs are done up tight enough.
Posted 9th Oct 2009 at 02:24
jimmy_boy
They sound very much like a sewing machine when it's the old valve stem issue Sad
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 9th Oct 2009 at 02:27
puglover Banned!
when you close the bonnet you can just about make it out. ill see if i can get a vid up as i need to know one way or another before i get it taken to Carls somehow.
Posted 9th Oct 2009 at 02:28
puglover Banned!
its not as bad as some of the vids ive been looking at i dont think but i just dont know. Sometimes i think oh its just the injectors and then i change my mind and think nah its tapping. If anyone is in the north west i would appreciate a second opinion and a comparison check to a sound engine. Its defo not plugs No
Posted 9th Oct 2009 at 02:34
fletch
Track Head
If you can only just make it out, I doubt its a tapper as they tend to be quite loud.
Could be loose plugs, very slightly bent valve, or lifters.
Posted 9th Oct 2009 at 02:33
i atarted mine for the first time in ages the other day and i thought id killed it, but after 5 minutes it went and went back to normal, did you get th elambda then??
saying taht though it did used to make me think it had a slight tap every now and again.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 9th Oct 2009 at 02:48
The MX-5 was the same when it'd been stood a while - it was on Magnatech too, and it'd formed some lovely black goop in the lifter, fookin shitty stuff... anyway, took a flush of oil and two 30 minute/3krpm warming up sessions to unstick it...
puglover Banned!
yeah i did LOL thanks dude i do live for the 306 Thumbs up shame its taking over my entire f*cking life at the moment though Sad
puglover Banned!
I will have a look tomorrow Smile thanks there is hope LOL
so you mean i shouldnt be able to push them down??
Posted 9th Oct 2009 at 03:09
urrggghhhhh magnashite Sad stick some total quarts stuff in it Thumbs up
Posted 9th Oct 2009 at 03:08
puglover Banned!
ill change the oil for some pug stuff as well.
Posted 9th Oct 2009 at 03:10
mechanical_repairs
Its hard to diagnose without hearing the engine, i take it it runs fine but just has this tick, if you rev it and it gets more pronounced and the noise gets faster i would say you have the tap.
If you can pop a video on here i could take a listen for you, sometimes though its hard as recordings tend to pick up alot of other sounds you wouldnt notice.
I have my fingers crossed for you, you seem to have been through hell with this.
Carl
Posted 9th Oct 2009 at 03:38
puglover Banned!
well its got the better of me and ive been and whipped tha covers off. The lifters are all pressed up to the cams and cant push them down Sad
Carl yeah it runs pretty well at moment nothing else seems to be wrong. But i havnt driven it yet and its a high boost engine so im taking my time with it. I know what you mean about videos been abit dodgy.
It does indeed get faster as you rev it but not really any louder.
How much do you charge to pick up a car from burnley??
Posted 9th Oct 2009 at 03:45
james_r
Gutted for you, when I bought the head it was good, then had it checked by QEP when they did the seats so hopefully it's not the head. fingers crossed.
Momentum is your friend, intertia your enemy
Posted 9th Oct 2009 at 21:58
puglover Banned!
no worries man, Im still in disbelief of it being a bent valve but will hopefully have a vid in few hours.
When you say it was good when you bought it does this mean taken from a sound engine??
If its bent valves the only answer is worn guides or a valve that slipped the net. Dunno but both these point to a head with a not so desirable history.
I take it they lapped the valves in??
Posted 10th Oct 2009 at 00:29
rich-6
I had the same on my car with the same oil, It took a couple of flush's to free it then it was fine now its got a noisy injector instead Laugh
Cool
RIP Pete Sims
Posted 10th Oct 2009 at 00:31
puglover Banned!
you sure about that LOL
Posted 10th Oct 2009 at 00:38
puglover Banned!
Its f*cked
Posted 10th Oct 2009 at 01:54
fletch
Track Head
Hmm that does sound rather loud. can you post back with what you have checked, as you have some suggestions but no indication on whether youve tried them or not?
Posted 10th Oct 2009 at 17:12
puglover Banned!
have checked lifters, plugs, unplugged each injector etc etc
the video really makes it sound shabba, im convinced its a bent valve now.
Only other possibile answer is the manifold gasket even though its new or the cat manifold join but the noise doesnt come from there. Its defo valve train noise.
Posted 10th Oct 2009 at 19:33
