displaying posts 1 to 25 of 35
Author Subject: bilstein b8/ eibach fitting noob questions
hi, ive received my billy b8`s from miles today and have a few questions about fitting them, some are obvious, id just like to clear things up.
first of all this plastic cover over the top and bottom coils is there to stay on? right?
then do i use the dustcovers from my old legs?
the old legs have a notch in them for the dustcover to sit here:
but the billys dont have this slot.
my dustcover has a slight tear on it:
should i replace it then, does anybody have the part number for them?
when offering the eibach spring to the billys, it doesnt seem to sit square at all
Crazy is it ment to be like this:
and wil straighten itself out when i put them together?
thanks katie
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 6th Oct 2009 at 00:32
1 yup
2 yup
3 up to you, dont forget to swap the bumpstops over if applicable too.
4 yes.
Posted 6th Oct 2009 at 00:35
hi, thanks welsh.
how do i know if its applicable to fit the bumpstops? i was going to as there was the other thread recent about the bumpstop.
my concern was the angle of the springs in the leg lol.
Posted 6th Oct 2009 at 00:41
You need the bumpstop on those - hence the small shaft.
Posted 6th Oct 2009 at 00:54
x69 rgg
andy+katie wrote:
hi, thanks welsh.
dust covers definately. my old ones didnt have dust covers on and had collected quite a bit of crap and i think that was what caused them to leak.
stick the stops on as well. as phil says they have a smaller shaft so an extra stop wont hurt.
although billies apparently have built in ones.
the springs will sit like that. get the compressors on the springs and they should sit a little straighter in the cup. i thought they were broken when i fitted mine. should give you just enough to fit the top mount on. then wind the nut on. easy when you know how. took me a few hours to get it right the 1st time.
have fun Smile
*edit*
forgot to mention. universal dust covers from tweeks for about
"I need to 're-mortgage' my six"
Posted 6th Oct 2009 at 02:12
stu
I'm just about to fit the same setup, coincidentally I was just about to post a thread asking similar questions.
The part number for the dust boot's is - 5254 13
I know it's correct because I picked two up from Pug on Saturday. Thumbs up
Also, if you need them -
Bump Stop Part No. - 5033 27
Top Spring Pan Part No. - 5031 37
Smile
Posted 6th Oct 2009 at 02:15
how much was the above parts stu?
if theyre not too bad on price i will just get them all and leave my other legs as a complete unit to either save or sell.
Posted 6th Oct 2009 at 14:46
The part number for the dust boot's is - 5254 13--
Posted 6th Oct 2009 at 18:37
ive bought some new bump stops and dust boots for these,
do the bump stops need cutting down, as there doesnt look much travel left when there on the shock??????
Posted 13th Oct 2009 at 16:08
paul_gti6_uk
I asked this in another thread as I never cut mine down but was wondering whether I should have. I dont think there was a definitive answer though.
China Blue 306GTI-6 Big grin Ph3
Team Now Bikeless Sad
Posted 13th Oct 2009 at 17:34
noooo!
well I dont think so anyway LOL
I would check with Bilstein how long they need to be.
Posted 13th Oct 2009 at 17:47
Don't know what Bilstien recommend but I use 60mm long progressive bumpstops that go from 75lb/inch to 350lb/inch at solid* height (which is 30mm)
*Well, given it's polyurethane, it's not exactly solid, but it goes north of 2000lb/inch in the next 10mm of compression, so...
Posted 13th Oct 2009 at 17:58
ahh no worries then, that makes complete sense to somebody like me lol.
all i know is theyre white and bigger than 60mm!!
Posted 13th Oct 2009 at 18:57
wel i built up 1 strut and i cut 20mm off the bumpstop, but somethings telling me i shouldnt of
Posted 14th Oct 2009 at 00:42
stu
I was wondering this the other day.
I think I'm just going to leave them as they are, won't do much harm will it?
Posted 14th Oct 2009 at 00:53
eddd
I asked this not so long ago as I had fitted bumpstops to this combo that were cut down one "notch", however this caused the suspension to clonk when going over heavy bumps, and it looked like it was the upper shock shaft hitting my top mounts.
As a result I fitted new full length ones and has been fine since, so in my opinion fit the standard length ones.
Team Nile™
Posted 14th Oct 2009 at 00:58
jimmyrallye
just leave orignal bumpstops on they will be fine Smile
Posted 14th Oct 2009 at 01:00
hmm, maybe i will take the strut back apart and fit a full size bumpstop then.
there just doesnt seem to be much travel at all left until the shock bottom reaches the bump stop.
must be like 2.5 inch
Posted 14th Oct 2009 at 16:03
306chris
i am just about to buy some B8's and eibachs, andy + katie, would you say they are worth the money?
My aim out of having them done along with new top mounts and drop links is too gett rid of the suspensions rattles i have and obviously have a better handling car. I have just changed lower arms on both sides so pretty much all angles will be covered when i gets shocks/springs done, however i dont want to spend
Posted 14th Oct 2009 at 23:47
You've only got ~6.25" of travel on your strut anyway, and it doesn't stop when it hits the bumpstop, it squashes it.
Posted 14th Oct 2009 at 23:48
Posted 15th Oct 2009 at 12:29
acos205
I fitted mine with full length bumpstops and ended up cutting them down as it looked as tho the front was sitting on them. Hope i did the right thing. Don't fancy stripping it all down again No
Posted 18th Oct 2009 at 05:13
yeah i measured it with the bumpstops in full and it left 1.5 inch of travel before they touched it, and thats before the car is on the ground, and i suppose it will sink atleast a bit.
Posted 18th Oct 2009 at 13:40
mad_dave23
how much did this lot set you back then?
Posted 18th Oct 2009 at 23:59
ive had the springs a while now they were about
Posted 19th Oct 2009 at 02:21
