Author Subject: rear beam negative camber
mxcrazy
Ive seen a few snippets of information regarding this, does someone do a set of stub axles allready machined/modified with neg camber, anyone prepared to do it or look into it if it hasnt been done allready?
The ZX beams i beleive have more toe in than a 306, is this done with the arms, or stub axles or what?, if it was stub axles could you rotate the pins circa 90 degrees to get camber?
many thoughts crossing my mind, but im sure you guys have had these same thoughts many moons before now. cheers
Posted 2nd Oct 2009 at 20:12
mxcrazy
And yes, i have searched but couldnt find anything that really helped.
Posted 2nd Oct 2009 at 20:16
Midlife has a negative camber rear setup, Miles also offers this service too but it does involve machining of spindles etc. Best to get in touch with them directly.
Posted 2nd Oct 2009 at 20:45
allanallen
Zx arms have 0 toe and 1.something negative camber. Its not achieved by the pin itself so rotating it wont do anything.
Pm crf450 on here about machining your arms
Facebook
Posted 2nd Oct 2009 at 21:04
beez_neez_gt
1.2 neg camber on ZX arms and no toe untill the cars been lowered then it will have a little toe.
crf450 will sort them out for you for less than
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 2nd Oct 2009 at 21:29
mxcrazy
Posted 2nd Oct 2009 at 21:50
allanallen
No, 6 beams have a little camber and toe. Its the rear disc equipped zx arms your after, getting fairly rare now I would think.
I know of several people who run them on 205s and rate them highly.
Facebook
Posted 2nd Oct 2009 at 22:15
Rich E Forum Admin
The ride height will not affect rear toe.
Posted 2nd Oct 2009 at 22:59
It does, very slightly.
Posted 2nd Oct 2009 at 23:00
as they have quite a bit of rear camber you'll introduce some as you go lower, you don't notice it as much on the 306 as they have toe in but not as much camber.
Xsara's have a lot of toe in.
Posted 2nd Oct 2009 at 23:09
Rich E Forum Admin
Ah true, I'd somehow managed to forget about the camber Doh
Posted 2nd Oct 2009 at 23:26
miles
The beams are rarely the same from side to side anyway, you need to measure them first and go from there really
www.pugracing.com
Posted 3rd Oct 2009 at 05:25
