Author Subject: Very high clutch pedal!
lotek
i have just changed my clutch and clutch cable ,
and my biting point is ridiculously high????
i dont know whats up i first thought that i didnt get the fork behind the bearing but i know i did and it releases ok. but the clutch pedal has to be released nearly all the way to get moving? also car feels a little slower , maybie the cable is making clutch slip??
anyone know why the pedal is sooo high?
Posted 30th Sep 2009 at 01:24
lotek
bump
lotek
cable was from gsf
and had T71522 on Packet...
Posted 30th Sep 2009 at 01:38
kit
Doesn't it have to adjust itself a little bit? Maybe if you give it a bit of time it will work it's way down to a more comfortable position.
Does it feel like the clutch is slipping or is it just loss of power?
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 30th Sep 2009 at 01:43
lotek
i would have thought that it would adjust straight away?,
i wouldnt say loss of power just revs go up quick but not speed dial as it used to?
if it makes any difference i struggled to get the cable on the clutch arm it was real tight.
can you manually adjust the cable??
Posted 30th Sep 2009 at 01:51
gti6-ginge
make sure its in the bulk head hole correctly and that its on the box mounts correct made this mistake with mine
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 30th Sep 2009 at 02:14
lotek
ok cheers,
how can i tell if its in the bulkhead properly ? i cant see shite up there, my string
snapped so had to put it in by hand lol
Posted 30th Sep 2009 at 02:17
gti6-ginge
if you unbolt the 10mm nut in the o/s/f wheel arch you can move the a/c pipes bit. take the cable off the pedal tie a shoe lace ( its stronger ) dissconnect from the gearbox end and repull the cable into the bulkhead. hope it helps
Posted 30th Sep 2009 at 02:25
lotek
il give it a whirl. Thumbs up
Posted 30th Sep 2009 at 02:28
webster
cable is self adjusting iirc
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 30th Sep 2009 at 02:31
cabbymeg
Doen't sound right tbh, should be plenty of cable to easily attach to the gearbox end.
Mine was a complete b*tch to get in the bulk head. The rubber grommit on the end id the hard part. I took it off and put that into the bulkhead first then the canle through. It was much easier that way
Posted 30th Sep 2009 at 02:43
fairy liquid does the trick, nice n slippery Big grin
Posted 30th Sep 2009 at 03:17
cabbymeg
Yeah, I ended up using Autoglym car shampoo though as we were out of fairy!
Posted 30th Sep 2009 at 05:19
lotek
FIXED IT!!!!!!!!!!
i disconnected box end , pushed cable then tugged it firmly , heard mechanical noise then it let me have a shed load more cable??? biting point is now real low !!! Big grin
Posted 30th Sep 2009 at 16:31
need to do mine but your seemed to be a pig lol
Posted 30th Sep 2009 at 18:08
gilesy
Just about to do my cable now...wish me luck!!
Oh, and
Posted 30th Sep 2009 at 18:55
lotek
Good luck mate. i did mine on my own and the string snapped which made for fun, i got the rage and just pipped the aircon pipes out of there holders and pulled them up a bit, then from underneath used jack handle to prod cable through the resulting gap.
MISSION!!.
im sure you will be fine.
Posted 30th Sep 2009 at 19:04
gilesy
This is a nightmare, I've been at it for ages...I just can't get the plastic bit through the bulkhead. I'm all connected with the lace etc and have gotten past the aircon pipes, am just a bit stuck now.
Posted 1st Oct 2009 at 16:47
russian
My biting point is really high too, could any of you guys get some pics up of how the cable should be routed, just to give a rough idea?
Posted 4th Oct 2009 at 03:43
