Author Subject: DTA Wireing Loom
itchytrigafinga
Hi,
Got a DTA wiring loom to go with a DTA ECU. It
Posted 25th Sep 2009 at 23:20
ablister
what ecu is it are there are a few diagams available
dta website
306 rallye, Richard Longman engine
rc10gt
Posted 26th Sep 2009 at 02:27
itchytrigafinga
dta website
I've got the E84 model one.
That diagram helps a bit, allthough i have the wireing loom already wired up and labled, i just dont know which connectors im surrpsed to plug into the 3?
Where abouts would i likely find them in the 6 engine bay? Hmm
Posted 26th Sep 2009 at 04:45
spiky
power will probably need a 12v feed
dash could be anything, like a shift light or something
relays could be to feed the fuel relays (mine is like this, send a earth to the fuel relays)
i also have fan control too,
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 26th Sep 2009 at 14:16
itchytrigafinga
Ahh ok thanks, so nothing standard on the car would fit these plugs? I thought thats what they might be for,
Cheers mate.
Posted 26th Sep 2009 at 14:25
spiky
get some pic's up Big grin
MY YouTube Videos'
Posted 26th Sep 2009 at 15:40
itchytrigafinga
Pics of the loom?
Hit another problem, took the cover of the top of the engine, and its got one plug per cylinder for the coils. The wireing loom only has one coil plug, how do i get aroung this? Do i need to get an adapter to make it only one plug?
Posted 26th Sep 2009 at 16:24
spiky
i run a coil pack
MY YouTube Videos'
Posted 26th Sep 2009 at 16:27
itchytrigafinga
spiky wrote:
i run a coil pack
Would i be able to get one off a standard engine with leads if they fit?
If i can do you know what cars i would be able to get them off. I dont have the coil pack and leads so would need to get them before i can put thebodies on etc and wireing loom.
Posted 26th Sep 2009 at 16:30
spiky
the lease are vaux corsa B leads
the coil pack is a 306 8v on
MY YouTube Videos'
Posted 26th Sep 2009 at 16:31
itchytrigafinga
Only plug we have left is the crank sensor plug, is this the one located towards the left of the rocker cover? The 3 pin plug?
Posted 26th Sep 2009 at 19:16
spiky
that is the one that bolts on the gearbox Big grin, i use a std gti6 crank sensor
MY YouTube Videos'
Posted 26th Sep 2009 at 19:17
itchytrigafinga
Ok, What happens to all the wires that are disconnected from the old ECU? there arnt enough plugs on the new loom to plug them in so they all connect?
Ive taken the old ecu out, im assuming anything connected to the eold ecu will not work?
Posted 26th Sep 2009 at 19:19
ablister
the 306 loom will be of no use when using the dta ecu/loom. All you'll need is the 2 wires for the reverse light switch on gearbox. You won't have connectors on the dta loom for some of the engine sensors, eg purge canistor.
the dta wiring diagrams will explain everything regarding 12v supply, relays, tacho signal etc
rc10gt
Posted 26th Sep 2009 at 22:03
itchytrigafinga
Yeah i thought about that. I have decided to leave it for the pro's to do now, all i will do is end up f*cking it up anyway Doh.
Cheers for the help.
Posted 26th Sep 2009 at 22:06
spiky
you remove the old ecu and all the loom Smile
MY YouTube Videos'
Posted 26th Sep 2009 at 23:08
itchytrigafinga
Yeah but there are like 3 of 4 connectors on the throttle body, one is the tps which is ok i had a cable on the new loom for that. But all the other 3 sensors dont have connectors on the new loom and i cant see its right that the bodies only need the tps connecting?
As said above, some of the factory ecu sensors wont work. I also dont think the fule relay has a connector on the new ecu, i think i willleave it to a garage.
Posted 26th Sep 2009 at 23:57
dj_turbo
All you need connected for it to run are:
Air temp
water temp
coil pack
crank sensor
throttle pos
injectors
Then
fuel pump feed / relay
Taco
earth
12v feed
You wont need any of the other sensors. just overide the idle control valve
Posted 27th Sep 2009 at 00:17
ablister
is this for a throttle body conversion? If so, all you'll need is the tps sensor and possible air temp for the induction side.
rc10gt
Posted 27th Sep 2009 at 00:15
itchytrigafinga
Yeah it
Posted 30th Sep 2009 at 01:30
spiky
no maf
no idle control
neither used on mine Big grin
MY YouTube Videos'
Posted 30th Sep 2009 at 01:38
itchytrigafinga
spiky wrote:
no maf
no idle control
How does it work though? Bloke seemed to think the ICV was for the servo assistance? And it was needed on the manifold as its the only place you get a vacum.
Wont it run like balls with no MAP sensor also?
Posted 30th Sep 2009 at 01:41
spiky
lol i think you need to stop talking to him...
mine runs perfect dude Wink
gti6 has a vacum pump remember that the servo connects on to
ICV is for Idle control..lol nothing to do with the brakes Big grin
MY YouTube Videos'
Posted 30th Sep 2009 at 01:42
miles
As said on bodies unless your taking Weber one's you don;t have a ICV or MAP so I think I would avoid any advice by your mate personally as he's barking up the wrong tree.
Coil pack wise just use one from a XSi, much neater and no messy HT leads
Look at what DJ's posted about what you need to run the engine is very little and it does surprize allot of people
www.pugracing.com
Posted 30th Sep 2009 at 05:32
itchytrigafinga
Say for example I wanted to fit the bodies and keep the standard ecu and loom, until I can get the loom fitted and the new ecu remapped, would this work or would I have any problems, provided I connect the tps sensor?
I know this would not be idea and is not intended to be a permanent solution.
Posted 30th Sep 2009 at 18:45
