displaying posts 26 to 39 of 39
Pages (2): 1 [2]
Author Subject: Group N oil pump Spring
allanallen
phillipm wrote:
It's not so much the coilbound length that matters - it's the spring preload, making it go coilbound to early will result in what you experienced - pressure going through the roof at high revs when the ports choke and seals popping out.
Mine was popping the seals at idle Shock I think there was far to much preload and the pump was giving the engine all it had!!
Facebook
Posted 25th Sep 2009 at 20:19
LOL
If you hang on I'll get some graphs up to show what I mean.
Posted 25th Sep 2009 at 20:23
allanallen
phillipm wrote:
LOL
Graphs! Who needs graphs, I was covered in bloody oil LOL
Facebook
Posted 25th Sep 2009 at 20:29
You out to start going clubbing with Rikky, I hear he likes that sort of thing....
Posted 25th Sep 2009 at 20:34
Right - these are just arbitary graphs, they're not from an engine, just a quick set of fluid flow calcs:
Anyway, assume this is a standard engine, once the bypasses choke, the pressure ramps up against the relief spring, which pops off and give a nice gentle rising curve thereafter (the gradient of the curve is altered by various designs around the port to make the blowoff more progressive, but hey..) :
Now, if you fit a longer spring of the same rate, you'll have more preload and the oil pressure will look something like this, as you can see the initial part of the graph ramps up faster and for longer before the relief blows:
And this is what happens if you cock things up, and install a spring/spacer so long, that even when the relief valve blows, it's still choking the ports:
As you can see, you end up oily.
Posted 25th Sep 2009 at 20:48
allanallen
Oily indeed
Its a shame its such a pain to keep stripping the pump and trying different size shims really.
Facebook
Posted 25th Sep 2009 at 21:01
/pats lovely port-flow calculator that predicts the right size shim for the pressure...Razz
Posted 25th Sep 2009 at 21:04
allanallen
Does it do lottery numbers too? LOL
Facebook
Posted 25th Sep 2009 at 21:08
Hmm
worth a shot.
Posted 25th Sep 2009 at 21:10
Post #35
So what size shim would you reccommend? Razz
Posted 25th Sep 2009 at 21:32
Post #36
Dunno, mine's setup for Nissan V6's LOL
Course, if you bolt one of those in I can tell you LOL
Posted 25th Sep 2009 at 21:40
mark.evs
Post #37
Sorry to bring up an old thread but its kinda the same subject. If an oil cooler is added, with the added extra length of oil pipes will there still be enough oil pressure by the time the oil gets back round to the cam and crank spray bars? cheers in advance.
My GTi6 track project
White Rallye project
Posted 19th May 2011 at 15:46
Rich E Forum Admin
Post #38
Yeah easily. There's nothing to worry about.
Posted 19th May 2011 at 16:41
mark.evs
Post #39
cheers mate. puts my mind at ease.
Posted 19th May 2011 at 16:45
Pages (2): 1 [2]
