displaying posts 26 to 40 of 40
Pages (2): 1 [2]
Author Subject: fans not working
eddy_gti6
still havnt worked my problem out yet??? LOL
Posted 8th Oct 2009 at 04:20
hitman_
Hey YO EDDY..
OK finally returned to the car after abandoning it for a while
checked the fuses
(all seem fine,)
took the bitron out
what am i supposed to be looking at on it..?
(all connections seem fine)
someone had been there before as it was glued together
oh and tell me more about this wiring harness for the fan PLEASE
Talk to me yo eddy_gti6
hitman_ has attached the following image:
Posted 22nd Oct 2009 at 22:22
gti6-ginge
hi everyone had a fault with my fans for a while now. only right hand one kicking in at 110'c. finaly got round to looking at them today and it turned out to be a earth fault in the wiring. had to remove the front bumper to trace the wiring back and found a the broken wire in the loom running under the rad on the front cross member. repaired and tested both fans now kick in on low speed at 95 - 97'c and both high speed kick in around 110'c. hope this helps anyone else who is having problems at the min
MY CAR WAS BUILT ON 17/03/2000 THATS A FRIDAY OH NO
Posted 28th Oct 2009 at 00:27
saveloy
I had both fans fail this Summer.
It turned out to be the fans themselves. A dealer only part at around
Posted 3rd Nov 2009 at 20:57
trell
I recon its the earthing box under the passenger side chassie rail just by the 10mm nut that holds the bumper on they get coroded and the pins break. i know this as mine had exactly the same symptoms.
Scorpion DEcat, Powerflow catback, Rebuilt head ( stage 1 ), Fast road Cams ( Kent ), Viper Induction, Cobra Monaco Pro's, OMP 10pt bolt in cage. port and polish 4 - 2 - 1 hi flow exhaust manifold and 200 kgs lighter
Posted 17th Nov 2009 at 07:33
horn
Sorry to jump on this thread so late, I am having the same problems, i have sorted the bitron unit in the wheel arch and the fan kicks in when the temperature rises. However no matter what i do, i can only get the drivers side fan to work... is it possible to bridge the 2 green relays to enable the other fan to work?
Any feed back would be a help.....many thanks!
just go faster
Posted 3rd Jan 2010 at 04:07
saveloy
IT'S THE FAN!!!!!!!!
Posted 10th Jan 2010 at 04:59
306er
Had to dig this up as my fans stopped today, sat in traffic to find my temp gauge touching the redShock
I think a manual witch to turn on fans is a good idea when in traffic, any updates to this eddy?
diablo 6 black 6 China Blue GTI 6
Posted 5th Jul 2010 at 00:24
hitman_
Just wanted to add i changed fans still nothing called electrical dude out and he done this as connector was the problem now all sorted fans are workin like a dream Roll eyes
Posted 5th Jul 2010 at 00:40
306er
Post #35
Will have the bumper off tomorrow and have a look Roll eyes
Posted 5th Jul 2010 at 00:48
af1-gti
Post #36
i have this problem, unplugged brown sensor and nothing happens!
Rich E wrote:
With the 306 Rallye the goal wasn't to make a purer or more focussed car. It was to make a cheaper car, and then cynically use Peugeot's motorsport heritage to make it appeal to enthusiasts.
Posted 15th Nov 2010 at 22:14
dendle89
Post #37
steve h gti-6 wrote:
When you pull the brown sensor, both fans should kick in on low speed then a few seconds later both should go to high speed if alls well.
If you only get the left hand one or none, check the relays which are located behind your grill in a funny square shaped black box above/inbetween the fans. Inside you will see two green relays and one black relay box.
Pull each one out to see if they have shorted out(maybe the right hand one IIRC), and or replace with some working ones.
Failing that unscrew the connector which is on the bottom right of the rad and clean the connectors best you can.
Thats a rough guide to how i sorted mine on my 6 so cant be too differant a priciple on your 6 matey.
Apart from the above is where you have to get the fans out and test them to see if they are working/or change the Bitron unit which is located in the front left wheel arch at the top left as you look into the arch.
Hope that helps you out matey
Hi mate, im having the same problem.... but when I pull the brown sensor out the fans work as they should (low speed to high speed kick in) but when im in traffic and gets hot, the high speed fans dont kick in..... any thoughts ?
Im guessing the Brown Fan Temp Sensor needs replacing ?
Team 6 Cylinders
Posted 16th Jan 2016 at 17:11
dendle89
Post #38
Also, can I swap these sensors ? i.e. swap a brown fan sensor with a green ECU sensor so I know the fans will kick in or are the sensors different ?
Team 6 Cylinders
Posted 16th Jan 2016 at 17:45
Post #39
All sensors are different mate.
Check the relays,fan relay wiring and fan motors Thumbs up
Posted 16th Jan 2016 at 18:41
dendle89
Post #40
Yea i've unplugged the brown sensor and fans come on at both speeds when they should, but when the cars running and gets up to that temp the high speed fan doesn't kick in - leading me to assume that its the sensor thats at fault, that sound about right ?
Team 6 Cylinders
Posted 16th Jan 2016 at 18:51
Pages (2): 1 [2]
