Author Subject: Bottom End Knocking
shakey
After each outing in the track car I return to the pits and leave the car running with the bonnet up. There's a slight knocking which stops after a few minutes. Is it shagged ?
If so what's my best course of action ?
Cheers , Steve
Posted 7th Sep 2009 at 01:58
lotek
thats a bit bizzare? it just stops? checked your oil level? also look at coilpacks and sparkplugs, willy had something simular happen iirc
Posted 7th Sep 2009 at 02:05
shakey
2 or 3 minutes and it stops. Oil is spot on, plugs are less than 12 months old, not checked coilpacks though.
Posted 7th Sep 2009 at 02:36
lotek
re torque the plugs and coilpacks. eliminate all the little things first.
although it doesent sound too good
Posted 7th Sep 2009 at 02:40
Is it little little taps and knocks?
if so its just the engine bits like exhaust cooling down and contracting that makes the noises Wink
Posted 7th Sep 2009 at 02:42
shakey
No it's deffo a mechanical knocking from down below
Posted 7th Sep 2009 at 13:38
bobdylan_55
how new is the engine?
309 GTi6-T
Posted 7th Sep 2009 at 13:45
shakey
82K on the clock which I was told as being correct by the previous owner. If it goes bang then so be it, I'll just have to sort it as and when. I was just enquiring if there was any way other than an engine out to fix a bottom end knock.
Posted 7th Sep 2009 at 19:05
Bearings and such can be replaced from below, it's just a bit of a pain doing all that overhead. Than again so is removing the whole engine, but as Lotek suggested, eliminate the small tests first before you start pulling her apart.
Posted 7th Sep 2009 at 19:08
