displaying posts 126 to 150 of 152
Pages (7): first .. 5 [6] 7
Author Subject: 6-point cages fitted, interest thread...
Post #126
I'll think about it.
Thought about it, no LOL:
Posted 13th Apr 2012 at 11:32
Post #127
after seeing the pics from that other thread of that cage, i miss mine Sad
Posted 13th Apr 2012 at 12:21
Post #128
LOL
Have to fit another one, with more bars....
Posted 13th Apr 2012 at 17:24
Post #129
Cage's are addictive, you just cant kerb the urge to get just another thing added.. Laugh
Posted 13th Apr 2012 at 17:25
Post #130
I've got two offcuts big enough to do those main hoop>a pillar stays....Whistle
Posted 13th Apr 2012 at 17:27
Post #131
I'd best give them a miss, give my funds a little time to recover. Laugh
Whilst im thinking about it though, i bought a load of this stuff a couple of weeks ago, would you recommend getting the stupidly expensive FIA approved stuff for the cage all around my head or do you think this will be upto the job?
http://www.rallydesign.co.uk/product_info.php?cPath=2143_2144&products_id=15540&osCsid=vp7rsgosisgkrmdcvtb5p667q7
Posted 13th Apr 2012 at 17:35
Post #132
It's better than nothing, but if you hit the cage hard enough you can still crack a helmet through that stuff.
Give the cage is pressed right against the chassis though, it may not be all that close once you actually mount the seats and sit in it.
Posted 13th Apr 2012 at 17:44
Post #133
I plan on removing the cross member thing that sits under the normal seats so i can mount the buckets as low as possible, hopefully meaning more room above and around my head. I'll see what space is like once the seats are finally in.
Posted 13th Apr 2012 at 17:47
Post #134
Think Rikky has a picture of his from the rear with the buckets mounted?
Posted 13th Apr 2012 at 18:42
Post #135
I can't find his project thread. Hmm Sad
Posted 13th Apr 2012 at 18:49
Post #136
http://www.306gti6.com/forum/showthread.php?id=138226
Posted 13th Apr 2012 at 18:58
Post #137
i was looking for that photo the other day and couldn't remember my photobucket info!
the pics from that thread are fairly old, but the cage etc remained the same. for the record my seat mounting was perfect, dunno who said it wasn't right but i didn't see a better way of doing it. felt 'proper' to me
the glue i used to stick them in with was quite good actually
Posted 13th Apr 2012 at 21:55
Post #138
Must have been the same stuff i glued your cage in with....
Posted 13th Apr 2012 at 22:13
Post #139
I found a couple of empty pritt sticks in my car, its better than i remember it being at school as the drainpipe in my car seems to be stuck in good and proper.
I also seem to have gained a nice steel rule. LOL Just let me know if you want it back Phill.
Thanks for finding the pic Mei, doing something similar to that is part of this weekends plan. Smile
Posted 14th Apr 2012 at 00:34
Post #140
Blatent theft! LOL
Posted 14th Apr 2012 at 11:44
Post #141
Your way works if you have a narrow seat, putting them that far away from the centrline causes the 'wings' of some seats to foul the hoop or B-Pillar, but if your particular seat/subframe combo allows you to use that position then yeah, its the ideal location. My wideboy Evo2s meant I needed to perch one side on the tunnel and one on the seat bars.
Posted 14th Apr 2012 at 13:07
Post #142
^That's what I ended up doing with Puglover/T400PUG's to get the seating position straight with his seats anyway, even without a cage.
Rikky (And Prism7guys) have their doorbars absolutely as far out as possible to make as much room for the seats as possible though.
Posted 14th Apr 2012 at 13:28
Post #143
my seats didn't foul the doorbars or B pillars, i had the cage pushed out right to the shell so it was stitch welded to the actual shell and at a guess about 20mm further out than normal
i had sparco evo's in it (not evo2's) - i'm 13 stone but pretty lanky so i wasn't too bad in the seat, felt fine
Posted 14th Apr 2012 at 13:37
Post #144
ah, phil'd said that
Posted 14th Apr 2012 at 13:38
Post #145
could always mod the tunnel, very common on 205's, the 106 has a second skin over that bit that can be removed, the tunnel itself is much smaller, not sure if the 306 is like that but judging by those pics it looks like it may be.
Posted 14th Apr 2012 at 13:39
Post #146
yeah it comes off, it's all hollow box section to allow space for the seat bolts etc to go into. there is about 45mm of empty sectiion around the tunnel (on each side)
Posted 14th Apr 2012 at 14:21
Post #147
It is Yes there is a box section either side of it that can be cut away if neccesary, but I tend to feel that it was put there for a reason, so wherever possible I don't cut about the structure unless I absolutely have to.
Post #148
Well, if you start chopping the tunnel you may as well keep going all the way around the edges of the floor and just stick some extra tube in...
Posted 14th Apr 2012 at 21:08
Post #149
Spaceframe...Love
Posted 15th Apr 2012 at 11:50
Post #150
If someone wants a rear half cage I've got enough tube left, and can fit one in within the next two weeks.
Main hoop, two rear stays + diagonal all fitted + welded to stiffen shell I can do for £375, would take 1-2 days depending on how well stripped the car arrives.
Posted 15th Apr 2012 at 21:41
