| Author | Subject: Cold Air Feed In Morettes |
ct-hdi
Regular Location: wakefield Registered: 22 Apr 2009 Posts: 167 Status: Offline |
What size cold air feed trumpet would i need to fit one into my inner lense on my morettes? also, any pics of people witgh this done? |
eddy_gti6
i have morettes with the air feeds in but no trumpet ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
ct-hdi
have you altered the outer bulbs? to do dipped and main beam or jst left the h4s in?any piping from hole t air filter? |
eddy_gti6
since that pic i have removed the other inner light and modified the outer lights so i could fit my H7 8k HID kit who needs main beam when you have them yes i have a pipe from the passanger side air feed to the air filter, i will gwt pics as soon is i get my front end put back on________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
ct-hdi
ok mate cheers |
ct-hdi
oh and which bulbs did you have in then? cause atm mine are dull as anything... and cannot be bothered with the hid conversion yet |
eddy_gti6
haha the HID kit costs about ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
chrisd306 wrote: ![]() just used 3 k&n cold feeds to get to filter, works ok. the outers are sidelights and dipped and full beam, need to wire them to a relay tho as i havent and were to dull!! ________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
ct-hdi
eddy_gti6 wrote: haha the HID kit costs about
ct-hdi
cud i use a h4 hid kit in the outer lenses on my morettes? and leave the h1s in the inners?therefore i got the side, dipped and main? and leave the cold air feed for something else/ |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
eddy_gti6 wrote: i have morettes with the air feeds in but no trumpet ![]() That pic is photoshopped isnt it? You don't have a rallye blank, you have just shadily extended the grille. Looks like you may of even done it in MS Paint ![]() Also, why have you got a light missing for and intake, and a missing fog too? ![]() ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
availablebmx
Regular Location: Leigh-on-Sea, Essex Registered: 24 Oct 2007 Posts: 355 Status: Offline |
I have an air feed trumpet in my morettes... I believe it's 74 or 76mm... And it fits real nice between the inner and outer of the morette fascia!________________________________________ Thomas - Black 6 rollin' on black 15's...197bhp - 155.8bhp/135.4ft-lb atw |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
availablebmx wrote: I have an air feed trumpet in my morettes... I believe it's 74 or 76mm... And it fits real nice between the inner and outer of the morette fascia! Pics, and where did you get them from. Dan ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
availablebmx
I can't upload any pics from my phone to this site hmmm... But if you want you can check some pics on my facebook? Thomas Pollard...I ordered them through my local car shop, they were e-tech ones and they came as a pair... ________________________________________ Thomas - Black 6 rollin' on black 15's...197bhp - 155.8bhp/135.4ft-lb atw |
5p1k3
Newbie Location: leicester Registered: 22 Feb 2009 Posts: 24 Status: Offline |
Just a quick word of warning guys, i had morettes on my old DT phase 1. I had taken the left hand inside lense out to use an air duct and got pulled for it by traffic police. They checked that the dip and main beam worked (which they do on the ph1 bulbs) and sent me on my way. The bulbs in ph2/3 have two bulbs so to remove your the inside lense your removing your main beam. Be carefull the last thing you want is a fine. ________________________________________ spike |
c_j_m
Seasoned Pro Location: Andover Registered: 23 Sep 2007 Posts: 1,917 Status: Offline |
Not true.Ph2/3 morettes are identical bar the outer cover to the Ph1's |
birk
The inner lamps are just used as extra lights, i have had ph1 and ph2 morrettes, they are both the same, and on both sets i removed the inner lamps, the outside lights do all the work, side, dip and main.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
erezmiz
Newbie Location: jerusalem Registered: 02 Nov 2009 Posts: 40 Status: Offline |
I want this Kit but there is something particular concern.What about the rain ... water is drawn into the pipe to the engine? its have strong sucktion, the air filter not let the water in? Erez |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
erezmiz wrote: I want this Kit but there is something particular concern. What about the rain ... water is drawn into the pipe to the engine? its have strong sucktion, the air filter not let the water in? Erez you'd have a Closed filter like a viper etc between the intake and the engine the only water you'd have being drawn into there would be rain water which would just soak into the sponge only a high volume of water would damage the engine! but never do this without a filter! availablebmx wrote: I have an air feed trumpet in my morettes... I believe it's 74 or 76mm... And it fits real nice between the inner and outer of the morette fascia! i'm hazzarding a guess that the trumpet will be a 74mm i've got a 76mm trumpet and morettes but the trumpet doesnt quite fit,.. so i'd say the 74mm one should be a perfect fit but measure the morette socket 1st Birk ________________________________________ Proud Member of the ASTOR Owners Club |
![]() ________________________________________ ![]() |
gnrlee
![]() ________________________________________ Proud Member of the ASTOR Owners Club |
marco gti6
Seasoned Pro Location: Troisvierges Registered: 09 Mar 2009 Posts: 1,350 Status: Offline |
crikey, thought this age would have been autodeleted by now ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee
hey what happened there,... it wasn't me that resurrected this thread I just posted on it because it was on the front page,.. someone delete a post to make me look a dumbass? ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
eddy_gti6
gnrlee wrote: hey what happened there,... it wasn't me that resurrected this thread I just posted on it because it was on the front page,.. someone delete a post to make me look a dumbass? ![]() ![]() ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
