displaying posts 1 to 25 of 234
Pages (10): [1] 2 3 .. last
Author Subject: SOS Track 205 16v Turbo
sosmotorsport
Ok going to do a build thread on my 205 we are in the middle of building for the beginning of next year.
Alot of folk will have seen it this year anyway but i have recently stripped it down to a bare shell to undergo alot of work due to the engine that will be going in it this time .
Going to start off when i first got it to the stage it is at now this will be a on going thread for the next few months as it gets built from start to finish and all in house.
A pic of the car first of all just a pretty std 1.9 gti .
then i converted it to a 2.0 8v turbo for the track.
at this time it was stripped out , a set of bucket seats and a safety devices multi point weld in cage
engine pretty much std except bigger exhaust and 14psi boost from the t25 turbo this putting out around 190 atf .
brakes were gti-6 285mm on the front and std 1.9 on the rear .
suspension was koni adj all round.
cosworth 2wd intercooler modified and fitted to the 205 .
End caps cut off and rotated 90 degrees
Factory !! :wink:
SOS Motorsport
www.sosmotorsport.co.uk
450bhp 205 16v Turbo
www.facebook.com/pages/SOS-Motorsport/159917677353556
Posted 11th Aug 2009 at 02:17
sosmotorsport
Next up a fancied a bit more power having owned a few high powered 205s in the past a wanted a play around with the engine alittle .
Biggest problem with the 2.0 8v engine is there has'nt been alot of them tuned in the past so we had to pretty much just make a spec up as we went alittle trial and error but was fun LOL:
sent my old turbo away to aet turbos to see what spec i could get made up for the std manifold and to my surprise they said could upgrade to a hybrid T3 (biggest i had heard of on a std manifold was a T28) so i gave them the go ahead and a week later .
old turbo against the new one
next up was an uprated cam shaft this car from CATCAMS a nice stage 3 cam
now with the bigger turbo and cam i knew i had to go for a stand alone management so i bought KMS management , to go with this i got my hands on a set of cosworth green 803 injectors at this stage the engine looked like this
after a bit off mapping with the new engine the inlet temp were alittle high so we went for a bigger intercooler this time i opted for a evo one
now at this stage i need to be able to get the power down so we went for a quaife diff and a set of toyo 888's cut slick tyres
so now able to get the power down we now had to be able to stop so decided to upgrade for the gti-6 brakes to a set of hi spec 4 pots and still able to keep the 15" wheels
That was the car for a while and at that spec we managed to get 230 / 240 bhp at the fly a nice figure and defo good power increase Smile
and not every day runs smoothly , burst water pipe Cry:
SOS Motorsport
Posted 11th Aug 2009 at 02:18
sosmotorsport
Plans were made for the car to get stripped again this time for the proper build and a nice 2.0 16v turbo engine (same as t16 but better spec'd) and a good few body mods inc seem welding , new cage and light weight panels now hoping for roughly 750kg and 350 bhp.
So car goes in looking like this
to this in no time , engine stripped out
now right back to a bare shell with everything off
SOS Motorsport
Posted 11th Aug 2009 at 02:23
allesclar
nice Smile
Team allesclar ®
sosmotorsport
of course being stuck on one of the lifts is no good so was moved into its possition for the time being and for work to commence .
so as it is in the weld and prep area
now completely completely striped ready for the engine bay to be seem welded and strengthened
SOS Motorsport
Posted 11th Aug 2009 at 02:24
sosmotorsport
This section will show how the engine bay has been seem welded and strengthened.
reason for this work is basically a 205 was never designed for hard track use and certainly not for high powered engines as this picture will show the strut top after a bit of hard cornering .
see how its started to dome.
so this is where the strength needs to be added
area gets prep'ed
now plates get tacked into position
everything gets checked making sure there 100% and then fully seem welded into position
now while preping the engine bay to seem weld i found a couple of rust patches so decided to cut them out and plate them up properly
section cut out and ready for a plate to be made and welded in place
now its not like you can just go out and buy in a section to replace it , so a section has to made up now for this all that was required was a bit of sheet metal , plasma cutter , square and a hammer :wink:
now a rough size is cut a shape can then be made to fit
now must be trial fitted
and when happy with the fit tack welded into place and then seem welded
and the rest of the engine bay seem welded
SOS Motorsport
Posted 11th Aug 2009 at 02:27
sosmotorsport
we'll engine bay pretty much complete except the cage work which will follow , i moved on to seam welding the inside of the car .
For this to be done correct and the cage to be 100% spot on i had to strip the dash completely out and then had to dress up every seam on the car again to be able to start the welding pretty much the same procedure as the engine bay .
inside untouched except seats removed
dash starting to be removed
completely stripped
getting prep'd
then seam welded
so now car completely seam welded its now time to move on to the new front cage to be made for this we are using 38mm cds tube and getting bent with out HUTH pipe bender.
reason for the new front cage is i was wanting it a bit tighter to the A piller and also wanting it to go straight on to the strut tops and cross braced at both doors and behind the seats.
first part of the cage in place
now a perfect fit to the A piller alot happier so now added the first part of the cage to go onto the strut tops.
SOS Motorsport
Posted 11th Aug 2009 at 02:28
sosmotorsport
Another part of the cage complete but ran out of pipe so will have to get more ordered tomorrow to get the cage finished off .
and the strut tops completely braced
then seam welded the subframe , now ready to be powdercoated
SOS Motorsport
Posted 11th Aug 2009 at 02:31
sosmotorsport
was back on the cage again trying to get it finished off , now pretty much 90% complete just a few we bits left to go on .
centre bars to support behind the seats
then both doors crossed
then the final side supports triangulated
next up am going to build up a trial engine to fit it in and make sure everything is fitting before it heads into the bodyshop to get prep'd and painted before the proper rebuild Big grin
SOS Motorsport
Posted 11th Aug 2009 at 02:32
sosmotorsport
well managed to make up a test engine today to try out positions for various parts and to make sure of clearance issues which i thought could be a problem , but after its in and everything tested its pretty much perfect to say the least 8)
a few teasing pics (now this will make me get the finger out)
and a pic to show the room to get in from the cage
SOS Motorsport
Posted 11th Aug 2009 at 02:34
c.a.r.
That is pretty awesome mate, going to be a serious bit of kit when done. Madness with the cage though, looks like you've taken all the scaffolding from a local building site and stuck it in there somewhere!
Engine is very interesting, look forward to the future updates...
'99 1.8 XS - Sold
'00 GTi6 - Killed by armco
'01 Cabriolet 1.8 - Sold
'96 Eunos Roadster 1.8 Import
Posted 11th Aug 2009 at 20:08
ohh yes you can LOL
Posted 11th Aug 2009 at 21:08
sosmotorsport
ohh yes you can LOL
told you before LOL LOL LOL LOL
SOS Motorsport
Posted 12th Aug 2009 at 02:34
sosmotorsport
Managed to get the last pieces for the cage in place and thats now all the welding and cage done , next up is the car will be getting fully prep'd for painting this week and will hopefully be painted before the week is out depending on other work . Thought it would have been quiet first few weeks in jan but is not and we are actually fully booked so will just have to find time to squeeze my own in or ill end up running well behind.
strangthing plates welded to A pillers and roof
roof also braced
and the last piece was to brace the cage onto the rear suspension points
the rear beam now fixes up through the floor and the cage to stop any flex this will go nicely with the group A beam we are building for it .
SOS Motorsport
Posted 12th Aug 2009 at 02:36
sosmotorsport
well today seen me in to start the preping the car , nothing to drastic needing done but few dents etc normal stuff for a car 20 years old LOL:
all filled and ready to prime
rest of the car stripped ready to start the paint work now all off the wiring loom , steering column and clutch and throttle cable oh and peddle box and servo LOL:
now this is total naked 8)
SOS Motorsport
Posted 12th Aug 2009 at 02:38
sosmotorsport
and on that note a was back in today to start the painting so had to give a few of the boys a shout as the team are still off till monday , so cheers guys :wink:
first off moved the car into the booth and panel wiped it all
then on to the etch primer
then started the high build primer
onit 8)
then full car primed
now ready to paint woohoo 8)
SOS Motorsport
Posted 12th Aug 2009 at 02:39
ohh yes you can LOL
what? dont believe me? ask garry with the supercharged gti6 205 Razz
not my fault you believe your useless local dealers!
Posted 12th Aug 2009 at 02:46
sosmotorsport
at the time of my build like i said the parts were all back order from the factory and no date when they would be in sure i told u this the last time as well !!!!
SOS Motorsport
Posted 12th Aug 2009 at 02:47
sosmotorsport
and for another little update ,
today seen the car go into paint , big ups to toffi nice job for first day back :wink: dont say a aint nice to ya LOL:
and on that note always bet on black LOL:
pictures really dont do it justice imo coz this really s to die for 8)
SOS Motorsport
Posted 12th Aug 2009 at 02:49
sosmotorsport
dubbed_up_daz wrote:
SOS Motorsport
Posted 12th Aug 2009 at 02:51
sosmotorsport
the car got flattened and polished and took back out the booth then back into position to start the rebuild , and build the engine.
now first off was to start by putting the steering column and servo back in
then the full car loom had to be put back in as i removed this for painting.
removed the tape so i could re tape and remove any wiring thats not getting used and make it alitte neater
part of the dash and wiring back in
one of my fav new bits hahahah and new master cylinder and res bottle and cap with float
nice new competition engine mounts
made a start at the brake pipes etc before the engine goes into place
SOS Motorsport
Posted 12th Aug 2009 at 02:53
sosmotorsport
then i started putting the proper engine together
nice new oversized forged pistons
ARP rod bolts
lightened polished and shot peened rods and fully balanced bottom end
new oil pump
next up was the head rebuild
the head got completely stripped and sent away to get skimmed and the valves recut
when it cam back the valves got lapped back in and refitted
SOS Motorsport
Posted 12th Aug 2009 at 02:55
sosmotorsport
head now rebuilt time to mate it to the block
cometic Multi-Layer Steel head gasket
manifold with black heat wrap
manifold fitted to engine
SOS Motorsport
Posted 12th Aug 2009 at 02:56
sosmotorsport
managed a bit more work on it over the weekend and last few days , spent alot of time having to get braided pipe etc made up ( not been easy :twisted: ).
got all the brake pipes made and engine bay ready for engine .
gearbox on engine and turbo fixed down inc all oil and water pipes fitted .
engine mounted up and fixed in
SOS Motorsport
Posted 12th Aug 2009 at 02:57
sosmotorsport
oh and also managed to pick up my stack dash
and made a start at making my group a rear axle
SOS Motorsport
Posted 12th Aug 2009 at 02:58
