displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: Rear Beam Rebuild Part Numbers
willygti
Got my car booked in for rear beam rebuild next weds, and i'm supplying the parts (as i can get them cheap) and want to make sure i'm ordering the right bits.
Anyone got them listed? I know niel (iplay) is the part no. guru so will send him a pm, but anyone else??
Team Ducati 748
2003 Subaru Impreza STi
Posted 6th Aug 2009 at 16:58
i think its miles who sells the rebuild kits on ebay
Posted 7th Aug 2009 at 00:01
depends totally on the condition of the beam when its stripped apart, I'd only buy direct as you can save a hell of a lot over most sources.
also, worth checking out the phosphor bronze items if you want a fit and forget solution.
Posted 7th Aug 2009 at 00:13
miles
Not to hand but as said the main dealer's should be able to get the bearing's & seals etc without any problems at all
Personally I;d never go for the phosphor bronze option as the bearings should last 10 years anyway.
As said as long as the tube and Pin's are OK then it's not too bad to do.
www.pugracing.com
Posted 7th Aug 2009 at 00:50
suppose if they last that long and only cost
Posted 7th Aug 2009 at 00:53
willygti
right so i've bought the 'rear beam rebuild kit' from peugeot [see below] - part number on my invoice is 513262 but not sure if that is the actual pug part number.
this is all that was included, does it look right as none of the bearings/seals are the same? Dunno
pic:
Team Ducati 748
Posted 9th Aug 2009 at 04:05
Rich E Forum Admin
That's the right kit but it's one per side Smile
Posted 9th Aug 2009 at 04:08
willygti
so i have to get another set of 4?
Team Ducati 748
Posted 9th Aug 2009 at 04:09
yup Smile
Posted 9th Aug 2009 at 04:14
willygti
balls, thought
Team Ducati 748
Posted 9th Aug 2009 at 04:16
pugheaven
you will also need arb seals, some cork o ring things and somethink else i think cant remember what.
Posted 9th Aug 2009 at 23:01
willygti
can you try be a bit more specific mate, will need to order today. cheers
Team Ducati 748
Posted 10th Aug 2009 at 14:15
pugheaven
if you talk to miles he knows all the bits you will need.
Posted 10th Aug 2009 at 14:17
felixthecat
willygti wrote:
pic:
Can anyone tell me where the part in the upper right goes? I am currently rebuilding my rear beam with new bearings etc but dont know where the black ring is for. It has the same diameter as the inner bearing.
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 16th Aug 2009 at 21:55
willygti
it goes on the smaller part of the shaft ie the furthest part into the main tube.
Team Ducati 748
Posted 16th Aug 2009 at 21:58
felixthecat
so first the black ring than the inner bearing (from inside to outside)?
Posted 16th Aug 2009 at 22:40
smithers
Can anyone confirm this or is it the other way round?? Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 4th Feb 2010 at 23:43
mxcrazy
Does anyone have the dimensions of the bearings to hand please.
Posted 5th Feb 2010 at 00:39
smithers
I've just put the inner ones in so cant give you them but the outers have the following details on them.
'DB 70216 TIMKEN TORRINGTON FRANCE'
1997 Black GTi6
Posted 5th Feb 2010 at 00:45
i didnt get the black part with my rebuild kit is this very important??????? please some one let us no a.s.a.p
Posted 5th Feb 2010 at 02:41
dommo
bo***cks, just found play in my rear beam where these bearings sit. The wheels aren't cambered yet though so I assume the beam is OK at this stage?
How do you get the trailing arms off to replace these bearings? Do you have to get the torsion bars out? Does anyone fancy changing the bearings for me? Razz
Edit - just found the rebuild guide!
Does anyone do beam bearing replacement on here? Or is it that shit a job it gets expensive?
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 10th Feb 2010 at 18:09
if there's play I'd say you'll need at least a trailing arm shaft as well as the bearings, fingers crossed the shaft hasn't worn through the bearing case.
Posted 10th Feb 2010 at 20:13
dommo
How much are the shafts welshpug? Do you get them second hand or new (expensive..?)?
Cheers.
Posted 10th Feb 2010 at 20:29
new direct they're about
Posted 10th Feb 2010 at 20:45
dommo
Bo-larks..
Am I best with a known good beam (no play) and changing the bearings on that for good measure?
Posted 10th Feb 2010 at 20:54
Pages (3): [1] 2 3
