Author Subject: Pugracing quickshift
clen666
Was just browsing miles' ebay shop and came across his quickshift kit.
Does anyone have one of these and if so what do you think of them?
Team 'unintentional rat look'
Posted 12th Jul 2009 at 18:23
chris with a pug
Didnt know he did a quickshift, do you have a link!!!!
Posted 12th Jul 2009 at 18:44
clen666
its not like the other quickshifts that attach at gearbox end, it replaces gear lever mount, I am curious......!
clickaroo
Posted 12th Jul 2009 at 18:48
chris with a pug
thats like the compbrake one, they are really good. bit fiddly to fit though
Posted 12th Jul 2009 at 18:56
clen666
ah I see. Just my gear stick has decided to snap off at the ball bit, so was wondering whether this would be worth fitting while sorting it.
Just a question of money now!
Posted 12th Jul 2009 at 19:07
tangy7
I got one from comprake not fitted yet, costs
Posted 12th Jul 2009 at 20:54
clen666
Posted 12th Jul 2009 at 21:03
tangy7
umm probably the same as any other quickshift of this kind. Will be better than standard.
I had one of this type on a 106, coupled with chopped gear stick and a GE one lol, it had a very short throw.
for
Posted 12th Jul 2009 at 21:08
clen666
ah right, didnt realise you were selling, thought you ment compbrake were doing them for that price.
also does anyone know how much the gear stick costs from peugeot?
Posted 12th Jul 2009 at 21:12
chris with a pug
there loads being broken at the momet id just grab one of those
Posted 12th Jul 2009 at 21:26
clen666
Good idea! Cheers for the heads up
Posted 12th Jul 2009 at 21:27
ken
so that quickshift, is it anygood then?
i will prob buy it, never heard of that make to be honest
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 12th Jul 2009 at 21:40
puglover Banned!
the pugracing shop is run by miles off here, top guy top products.
Posted 12th Jul 2009 at 21:42
tangy7
LOL comprake are selling them at that price.
I've rarely seen them second hand and
Posted 13th Jul 2009 at 01:14
kust noticed this myself, i may buy one!!
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 13th Jul 2009 at 02:03
deanstacey
I have one of these from Miles.
Firstly, I have had other bits from Miles and they work fine.
A few things to be aware of.
Mine didn't come with fitting istructions. I'm mechanically OK with fitting bits but it would have been helpfull! Miles mailed me a quick list of how to fit them.
Unfortunately it was for a 5 speed box as he'd never personally fitted one to a 6. Which meant I had to find out via the forum what to do with the reverse gear selector which is bonded to the gear stick. This has to be removed with a sharp knife and then held in place with a hoseclip when you've put the stick in place. It also needs to be trimmed back as it expands when cut and the lift bit wont slide back over it - I used a dremmel.
Once fitted the real problems started. The two collars supplied have bad tolerances which resulted in the stick moving about in the ball joint. They are held in place by two grub screws that are at 180degrees to each other. This, added to the gaps between the shaft and collar, meant that moving the gearstick basically pivoted the collar on the shaft and after a short period of time caused the colar to come loose. This was usually the bottom one which was too big for the housing and meant that you had to force the gearstick into gear. You then have a floppy stick to drive on as you can't get to it to tighten it back up due to having to access it from underneath after removing the heatshield by the glowing hot cat!
After this happening for 4 or 5 times (Usually after about 15miles of driving) I'd had enough. Speaking to a friend about it, he mentioned that he had a lathe - so we made some more collars with tight tolerances and grub screws at 90deg.
Now done 140miles and nothing has moved or fallen off.
So, yes, the QS works great if you have a lathe to make some new collars.
Dean
Posted 24th Jul 2009 at 19:09
^^same thing he said good bit of kit tho but always have agro with it just wrap electric tape around the gear stick and ram it on done the job for me and i love it LOL
Posted 24th Jul 2009 at 19:20
i asked miles and he said hes having some newer updated version made up at the moment.
i dont know what the difference will be
Posted 24th Jul 2009 at 19:28
deanstacey
I sent him pictures of the collars I made, so hopefully the new ones will have tighter tolerances and grub screws at 90deg.
I agree with Hovis though, love the short shift
Posted 24th Jul 2009 at 21:30
pugheaven
Iv had one of there sat on my shelf for ages. Tried to fit at the weekend but like ppl have said the top hat bush that secures the bearing fouls the inside of the alloy mount. Has anyone got any pics or info of how they modified it. Cheers
Posted 10th Feb 2010 at 15:07
steve h gti-6
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 10th Feb 2010 at 16:44
pugheaven
Just spoke to miles and he wont be making any new top hat bush's for a few months. Looks like i will have to make the bits. Any info would be a great help.
Posted 10th Feb 2010 at 18:06
ken
i may need help fitting mine? i bought one off miles,
and im confused by the instructions lol :S
Posted 3rd Mar 2010 at 05:31
