Author Subject: 88mm (diesel) crank conversion
paul_13
Is the diesel/1.9MI crank conversion possible with the 6 engine?
I've only ever heard it done with the S16 engine.
What have I got to look out for?
Thanks
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 11th Jul 2009 at 06:50
matty_rallye
Yes it is ok to fit, im running a 1.9d crank in mine!
2.1 16v 306 Rallye.
Posted 11th Jul 2009 at 14:22
paul_13
What bearings and thrust bearings did you use?
Did you get a thicker headgasket?
Posted 11th Jul 2009 at 17:26
carl.swan
which diesel engine is it then? 306TD?
8th 2008
14th 2007
29th 2006 (Novice Year)
Yokohama Demon Tweeks Stock Hatch Championship
swanracing on youtube for video's
Posted 12th Jul 2009 at 15:43
mattb-6
You can run standard bearings, or whatever you require for your crank main bearing sizes if its been reground.
You will ideally need different pistons which will need to be machined (2mm removed from crown) to sit flush with the block at TDC, this also requires larger valve reliefs (2mm deeper) to be machined. I'm not sure if theres enough material on the standard to pistons to allow these to be machine, but I think that would be a bit risky. By doing all this you keep the head gasket/head all the same.
The crank would be from a 1.9td XU engine.
No more Pugs... Team Focus RS now Big grin
Posted 12th Jul 2009 at 15:55
paul_13
It will be a 1.9TD crank from a 306.
Thanks for the advice Mattb-6, I am looking to buy a spare block at some point and build this up gradually, then put the engine in place.
When you say valve reliefs, is that the valve seats? Sorry i'm not that clued up on engine terms, I know the basics.
Also standard bearings from a gti6 or diesel?
Posted 12th Jul 2009 at 16:01
S16 rods + pistons, no machining Thumbs up
Posted 12th Jul 2009 at 16:03
paul_13
Bugger! Just sent some out to portugal to a forum member
Posted 12th Jul 2009 at 16:19
mattb-6
By valve releifs I mean the machining in the top of the pistons to cater for the valves.
Even with S16 internals I think you will need to do some machining. The S16 is designed for an 86mm stroke and so with 88mm stroke at TDC the piston crown will be sitting 1mm above the block deck which basically is not good. I would suggest you would want to take 1mm of the top of the pistons so that it sits flush and keeps your squish volume correct.
As for bearings, you can in theory run either diesel or gti6. I would personally stick with the gti6 bearings (or uprated versions of them).
Posted 12th Jul 2009 at 22:42
carl.swan
1.9 8v xu no good? I have a 205 1.9 engine that i could strip down
8th 2008
14th 2007
Posted 12th Jul 2009 at 23:32
paul_13
I have a set of 1.9 8v pistons but i've a feeling they're no good.
Oh well will have to get some forged jobbies Smile
Is this conversion a no go with cams aswell?
Posted 13th Jul 2009 at 04:02
mattb-6
It will be no problem using uprated cams, but you will need to increase the valve relief depth further to give clearance for any higher lift/longer duration cams.
Posted 13th Jul 2009 at 13:28
S16 pistons are flat top and sit 1mm below deck on an 86mm crank, Razz
Posted 13th Jul 2009 at 17:16
mattb-6
Really, interesting to know.
From memory, the valve reliefs on the S16 pistons is very small - I would imagine these would need increasing at least...
Posted 13th Jul 2009 at 18:16
no, the S16 ones are huge compared to the gti6.
Posted 13th Jul 2009 at 18:38
paul_13
What kind of BHP/torque figures have people gained from this conversion compared to the standard crank?
Posted 13th Jul 2009 at 22:13
16v205
Hi
Are you on drivers at all? I built a 2140cc engine with a few extra bits.
Clicky
205 Gti-6 223bhp & 190lb/ft, still running in Smile
Posted 15th Jul 2009 at 19:51
paul_13
I am indeed mate, just had a glance.
Very interesting read, basically a step by step guide Big grin
Posted 15th Jul 2009 at 23:05
mattb-6
A few months back I read on 205drivers about a guy who ran one of the 2.1td cranks in an S16 block.
I happen to have one of these cranks sitting in my garage however the big ends measure 2mm wider than the standard XU10J4RS engine. Anyone know how the guy got around this, I'm pretty sure he was running S16 rods...
This Thread!
Posted 16th Jul 2009 at 20:27
paul_13
Ah Sarty's build, i'll have a gander over it and come up with an answer.
Another bloke on 205 drivers used the diesel thrust bearing and put a few tacks on with the welder then ground them off to size to make up the tolerance issues.
Posted 16th Jul 2009 at 21:53
mattb-6
Cheers - I tried to register to ask the question, but it said the board is no longer accepting new registrations... Sad
Posted 16th Jul 2009 at 23:50
send one of the admin an email, they're doing it manually at the moment I believe
Posted 17th Jul 2009 at 03:58
ryangti6
Ive been looking into doing this too the 1800 bottom end.
Does anyone know whats needed to do this?
Sorry for the ot Paul.
Ryan
Posted 17th Jul 2009 at 20:32
snooks
There are some good threads on 205drivers regarding this engine also. Best conversion using the XU7 engine is Mi interals with a XU10J4RS head.
Posted 17th Jul 2009 at 20:43
paul_13
What crank is better to use the 1.9 16v MI crank or the 306 diesel?
I think one is fully counterweighted other isn't, also what about bearing width on both?
Posted 17th Jul 2009 at 21:44
