displaying posts 1 to 25 of 53
Pages (3): [1] 2 3
Author Subject: 205 GTI180 Conversion
hanpug25
I've finally found the time and funds to make a start on my 205 project.
The plan originally was to keep the car stock and stick gti6 brakes and engine into it.
Things have changed a little now and I've aquired an OMP 10 point cage and a 206 gti180 engine and box.
The car is still giong to look standard inside and out, with the exception of the cage (going to paint it steel grey to match the body colour of the car - dont want it to really stand out) and all of the seats etc will be kept, even if the rears will be un-usable (may be able to get the baby seat in!.
Externally, I've already fitted the 309 rear axle and wishbones, as well as the slightly thicker 309 ARB to take the extra engine weight. Gti6 calipers are also fitted.
I'd already aquired a couple of 6 engines, but last week was offered a 206 gti180 for a stupidly low price. I know this conversion has already been done, but its not as common as the 6 swap and the VVT and noise of this engine, along with 180+ bhp standard, makes it a no brainer - plus ive managed to cover the purchase cost of the donor car without selling anything engine wise (so kinda got a free engine Happy )
Donor car:
The engines only covered 44k and is still very clean. I'll add more pics when I get chance.
If anyone has already done this conversion, or knows someone that has, Please let me know as I'm gonna really struggle with the wiring Crazy
Cheers guys, More to follow.
Passat B5.5 TDi estate (174bhp, 260 lbs/ft)
Posted 17th Jun 2009 at 17:04
you WILL need aftermarket management, Dutchman Hilgie (205 V6 builder) has documented a lot of the details of an EW-205 conversion.
Posted 17th Jun 2009 at 17:45
hanpug25
Cant you just stick the 206 180 stuff in there like with a gti6 conversion? It works in a 206?
Posted 17th Jun 2009 at 18:35
its a Multiplexed car, so if you did want to use the original ecu, you'd need to wire up the while car, instrument cluster, lights doors etc etc...
not impossible, but far more difficult than just fitting say a DTA or emerald ecu.
Posted 17th Jun 2009 at 20:02
Denis
You also would need to cut the cradle for the top engine mount and re-weld it slightly further forward. Brake master cylinder might be an issue as well.
Just found this thread on 205drivers: link
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 17th Jun 2009 at 20:17
hanpug25
Cheers for the link. I can find a ton of stuff on the 138 engine, but cant find much relating to the 180 setup in the 205. I'm a fab welder so the fabrication is not an issue. The wiring will be! Think Carl will be up to the challenge???
Sounds like its going to be a nightmare to convert, and the more I read, the more the 6 engine route appeals, but its a healthy, low mile engine with 180 brake out the box - maybe more without the CAT and airbox setup...
Was planning on moving the MC to the passenger side anyway. Mondeo's have the linkage and the 206 has something similar I may be able to modify.
Posted 17th Jun 2009 at 20:46
180 out of the box...
Posted 17th Jun 2009 at 20:41
hanpug25
Always wondered what preplexed and multiplexed meant...Care to expand a little, cos I dont get it.
What sort of money is the after market management? This is the bit that scares me, fabs, not a problem but the wiring Cry
Posted 17th Jun 2009 at 20:43
hanpug25
180 reliable standard brake.
Posted 17th Jun 2009 at 20:44
lighter engine too Wink
get yourself onto forum.205gtidrivers.com, it's been done, and documented a few times on there.
Posted 17th Jun 2009 at 20:53
hanpug25
Cheers for the info Thumbs up
Posted 18th Jun 2009 at 00:27
miles
Multiplex cars are a pain, they need to talk to each ECU and with all the ABS, Traction Control rubbish won;t work unless you have a degree in Electronic's to figure it all out
Aftermarket ECU is a doddle to fit, Just need mapping and then done
www.pugracing.com
Posted 18th Jun 2009 at 00:49
hanpug25
What sort of money am I looking at and who in the Midlands can help me?
Posted 18th Jun 2009 at 01:04
hanpug25
Its begun...
The engines out...
And the bays had the initial clean...
Next I'm gonna clean all the pipework and wiring out and pull the 180 engine out of the 206.
Posted 18th Jun 2009 at 01:07
jib
Interesting thread is this. Can i ask what made you decide to go down this route rather than sticking a 6' engine in?
Posted 18th Jun 2009 at 01:09
hanpug25
Seemed a good idea at the time Crazy Got the 206 on Saturday and I couldn't resist at 1200 quid! I took it for a blast and I was convinced!
To be honest I wanted something a little different, and the fact the engine only has 44k sold the idea.
Didnt think the wiring would be such an issue. Have read about people putting these engines in earlier 206's with the preplexed loom so that may be one option to look at...
Posted 18th Jun 2009 at 01:38
berger
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 18th Jun 2009 at 01:43
hanpug25
Posted 18th Jun 2009 at 01:47
captaink
Nice going with the 205 GTi180 project. I've got a 205 GTi6 myself and its a fun car.
Are you gonna put the 205's 1.9 engine into the 206 afterwards? LOL
When I got home last night, my G/F demanded that I take her somewhere expensive - so, I took her to a petrol station.
1993 L reg 205 with GTi6 engine and GTi6 brakes
1995 M reg FTO GPX manual
Posted 18th Jun 2009 at 19:10
paul_13
Big grin Nice! I'll be keeping an eye on this one
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 18th Jun 2009 at 19:19
n.g.k
Cool. Can't wait for the finished product.Cool
Inside you are face!
Tune Of The Month
Posted 18th Jun 2009 at 21:43
hanpug25
Started to take the engine out today:
Hydraulic clutch and a load more wiring than a 6 engine. Can anyone reccomend a company in the mids that can sort the management?
i'm going to try and keep the header tank and the Rad looks small enough to fit the 205 Happy
Posted 20th Jun 2009 at 01:45
mabgti
NV motors
good idea this... not seen it done before..
if you need a hand give me a shout..
management wise.. id get the specs on all the sensors and figure out what sort of ecu you want...
megasquirt] springs to mindYes As theres quite a few maps out there for the 180 engine on bodies etc..
i wouldnt let anyone but wayne schofield (chip wizards) map pugsSmile
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Jun 2009 at 02:26
hanpug25
Cheers for the tips. Thats the main reason I'm doing it, the fact that its a rare conversion, all be it a difficult one!
I'm useless with the electrical side so gonna need all the help/advice I can get on that side of the conversion Unsure
Posted 20th Jun 2009 at 02:32
paul_13
Going to be quicker than dribbly sh!t off a shovel Big grin
Did you see the Topgear where they raced a GTI180 against a 1.9 8v 205, 206 kicked its arse.
Image that in the 205! Big grin
Make sure you keep updated with pictures... Thats an order! Razz
Posted 20th Jun 2009 at 07:58
Pages (3): [1] 2 3
