displaying posts 1 to 25 of 28
Author Subject: KW Questions
stu
Afternoon all.
This afternoon I finally got my new front suspension bits fitted, it only took me about 3 months! Laugh
Anyway, I've just put the wheels back on and when I started to lower the car down off the jack, I noticed that the wheel was getting stupidly close to the spring. See pictures below -
I can't even fit my fingers between the wheel and spring!
I'm pretty sure that this isn't normal.
Now, the way I interpreted the instructions, that came with the KW's, about how to set the ride height to it's highest setting was to wind the spring down so that there was a gap of 15mm from the bottom of the thread to the base of the spring perch (15mm was stated in the instructions as the minimum amount of thread which should be left).
Now, have I been a complete 'tard and got the instructions the wrong way round, and should I have wound the spring up the shaft to achieve a higher ride height? I think this is most probably the case but I would just like someone to confirm it for me. Going by the instructions again the maximum amount of thread which can be exposed is 55mm.
I think I have been seriously affected by the heat because I seem to be doing everything wrong today!
Any help on this would be greatly appreciated. Smile
Posted 14th Jun 2009 at 22:22
puglover Banned!
perfectly normal that mate. the lower you wind it down the lower your car sits LOL
Mines about 5mm from the tyre LOL but there is no reason for it to touch so it will be fine.
Posted 14th Jun 2009 at 22:34
dragoon
i have about 3mm space between spring and tyre, so you will def. be fine Wink
and the higher you wind it, the higher your ride height
kw v1 with 17*7 rims on et15, i have put a spacer of 3mm to make sure i have enough space (so et12 in the end and no more problems)
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 14th Jun 2009 at 23:08
mabgti
NV motors
All depends on your offset.. ideally run ET 16 on 17" wheels for a nice clearance.. No chance of catching really.. As the wheel will always be perpindicular to the shockYes
P.S Anyone else think they need stronger helper springs?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 15th Jun 2009 at 00:18
puglover Banned!
helper springs arn't there to aid spring rate thats why they are fully compressed. take the load off momentarily and they can only go one way which is what they are there for to keep everything seated
Posted 15th Jun 2009 at 00:32
stu
Cheers for clearing that up, I obviously didn't read the instructions properly.
My Turini's do have an offset of 16 so I think I should be ok there.
Just need to wind them up now I suppose.
Cheers again for the responses. Thumbs up
Posted 15th Jun 2009 at 01:37
mabgti
NV motors
A stronger helper spring can give a more progressive feel.. which in turn could give a bit more reboundYes Especially on V1's
I know its main use it to keep tension in the strut on full extension using such short springs..
anyone know what poundage the KW main springs are?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 15th Jun 2009 at 02:29
The problem with using stiffer helper springs that don't compress fully when the car is on its wheels is that you'll have a very soft spring rate unless you alter both the main and the helper.
Posted 15th Jun 2009 at 03:40
puglover Banned!
i think standards are about 347lb mabs
Posted 15th Jun 2009 at 16:50
mabgti
NV motors
347lb? can anyone confirm that?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 16th Nov 2009 at 00:02
347lb?! holy f*ck!! Crazy
Posted 16th Nov 2009 at 00:09
I don't run helper springs on mine btw.
Posted 16th Nov 2009 at 00:10
rich-6
Do you just wind the seat up higher then?
Mine have about 5mm between the tyre and strut too, I thought it was odd but checked a mates golf and his is the same, I was a bit worried about winding them down some more Laugh
347lb is bloody hard if thats what they are.
Not that you can do it on 6s but i run h&r camber bolts on mine at 1.3neg i wouldnt want to go any less TBH just incase they slipped if i hit a f*ck off pothole Dry Tyre against strut = Crazy Blink
Cool
RIP Pete Sims
Posted 16th Nov 2009 at 02:30
Nah, but i've got different coilovers, softer springs and it runs at about a 35mm drop max. Been airbourne a few times with no problems.
Posted 16th Nov 2009 at 03:54
runs the right length spring for the piston length Wink
Posted 16th Nov 2009 at 04:14
mabgti
NV motors
anyone got a part number.. deff need to go softer. i'll give kw a call tomorrow.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 16th Nov 2009 at 04:16
You can get the springs from anywhere, not just KW. Just measure the diameter/length/number of coils/thickness just so you know what you currently have.
Posted 16th Nov 2009 at 15:51
birk
I want to get my Kw's down a tad lower then they are, fully wound down and still not low enough, could i just take the helper spring out ?
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 16th Nov 2009 at 21:20
dragoon
yes you can, loads of people drive without helper springs around here
and yeah, kw is hard as f***
(got a kw v1 with the springs of a v2)
Team Wheelwhore
Posted 16th Nov 2009 at 21:38
Not if they unseat when jacked up Dan, the whole point of helper springs is that they let you run a shorter main spring.
Posted 16th Nov 2009 at 21:54
birk
I imagine they would unseat when jacked up, any other way i could get it lower ?
07889376885
Dan
Posted 16th Nov 2009 at 23:34
run a softer spring
Posted 16th Nov 2009 at 23:42
Run a shorter main spring and a longer tender.
Posted 16th Nov 2009 at 23:45
mabgti
NV motors
so anyone know the best poundage to aim for? phill got any springs to try?
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 17th Nov 2009 at 01:23
Depends what size the KW springs are?
Posted 17th Nov 2009 at 20:59
