Author Subject: Rear beam differences
anderoo
What differences are there between the rear beams on different phases and models?
I'd like to build up a new beam with replacement bearings, hybrid arb and the 21mm torsion bars and I've got a couple of beams from Phase 1 D Turbo's that are availible to me.
If I build one up and switch the hubs over from my current beam would it be up to GTi spec or is there anything else I need to consider?
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 1st Jun 2009 at 17:00
some wont have anywhere to put an ABS sensor, and if they're a drum beam will have shorter stub axles.
I'm unsure if the camber/toe vary on them either, its quite likely so you need to ensure you use a pair of trailing arms.
Posted 1st Jun 2009 at 18:02
Get yourself a Xsara VTS rear beam mate.has the 21mm tb's and as your rebuilding it you know it will be fine!Thumbs up
Posted 1st Jun 2009 at 18:11
andy798
Is it just the Xsara VTS that has the 21mm Torsion bars or do all Xsaras have them?
I have an 04 Xsara Estate company car and if that has 21mm bars im sure knowone would notice if they were to end up on my 6! Whistle
1998 Blaze 6 - Now in bits Sad
Posted 21st Aug 2009 at 15:19
ZX have them as well, although not sure on the model. Pretty sure some of the estates have them as well. Welshpug will know!
Posted 21st Aug 2009 at 20:44
jjj10
As the torsion bars are external, it's quite easy to turn up at your local French car breakers with a vernier & measure the diameter.
Posted 21st Aug 2009 at 21:05
anderoo
Are all the beam tubes exactly the same?
If my beam has gone can I replace the tube with one from a DTurbo, reuse my trailing arms (replacing the shafts if worn) and keep the GTi-6 spec camber/toe etc? Unsure
Pics of my 6
Posted 11th Mar 2010 at 01:49
yup they are all the same
And this myth that the estate 306 has the 21mm bars is bollox
Well according to pug anyway when I got them to check on the system ??
Posted 11th Mar 2010 at 05:23
anderoo
Looking on servicebox the 21mm bars look like 515081 (LEFT DIAM 21 VERT CLAIR) and 515082 (RIGHT DIAM 21 VERT CLAIR) and are 90.25 each.
Pics of my 6
Posted 11th Mar 2010 at 12:51
tell them to remove digit and actually check properly Thumbs up
5150 81 and 5150 82, left and right 21mm bars as listed above, are 100% shown on SB for a 306 estate.
Posted 11th Mar 2010 at 16:07
LOL LOL
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
