chipwizard
Ex SC-6Now in a Megane R26
Author | Subject: ECU Unlocking Services |
![]() Seasoned Pro ![]() Location: Leeds Registered: 26 Dec 2005 Posts: 5,940 Status: Offline |
markrallye wrote: Rich or wp. Whats Waynes user name on here as I have a bosch one that needs unlocking and as he is in my neck of the woods. Cheers chipwizard ________________________________________ Ex SC-6Now in a Megane R26 |
![]() Seasoned Pro ![]() Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
mabgti wrote: does the standard immobliser still work with unlocked ecu's? No - the main purpose of unlocking them is to remove the immobiliser. ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
[b]I have more unlocked ECU's than I know what to do with now - so I am doing them for ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
![]() Senior User ![]() Location: Reading Registered: 10 Dec 2008 Posts: 693 Status: Offline |
Want another GTI6 ecu?It's locked, yours for postage fees ________________________________________ 205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit.![]() Private work, not a prob ![]() |
![]() Senior User ![]() Location: RAMSGATE, KENT Registered: 15 May 2009 Posts: 506 Status: Offline |
is it possible to pre-map an ecu using a template kind of thing?i have a magnex cat-back and an induction kit, didnt know if you could do anything around these or do you have to have the car to play around with? i have already got one of your ecu's from a while ago if that makes a difference ________________________________________ fixed my heaters and found out my aircon works![]() |
-sinden- wrote: is it possible to pre-map an ecu using a template kind of thing? i have a magnex cat-back and an induction kit, didnt know if you could do anything around these or do you have to have the car to play around with? i have already got one of your ecu's from a while ago if that makes a difference Hi mate, I'm afraid not, I don't have a map on file for that particular setup. TBH, you don't stand to gain much unless you take your mods further with cams or something. The standard ECU is very refined, hence why Superchips and the like do fook all. ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
![]() Seasoned Pro ![]() Location: The Nam Registered: 24 Jan 2006 Posts: 12,828 Status: Offline |
goliath wrote: Rich_w As welshpug mentioned above I would be interested if you could unlock a 406 V6 ecu, running bosch MP7.0 management. Let me know if its possible ![]() Nice to see you on here matey! Rich, would it be simple (ie cheap) to increase the rpm limit then? Mine won't gain from it due to the cam advance, but I know someone who will be interested ________________________________________ Nothing to see here |
Yes, it's fairly easily done.I need to get Wayne to do it - I don't have the knowledge to find the RPM limit within the BIN file. To confuse matters, the RPM limit is in different locations, and the width of it in 'bits' can vary depending on the software version, which is why Wayne needs to do it. Can get it done if required though. Price I would need to confirm with Wayne, probably ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
BUMP FOR THE WEEKEND![b]STILL DOING UNLOCKED '6 / RALLY / XSARA VTS ECU'S FOR ONLY ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
Post #35
Wednesday afternoon bump ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
![]() Seasoned Pro ![]() Location: Durham Registered: 20 Oct 2008 Posts: 8,716 Status: Offline |
Post #36
will the unlocked gti6 ecu work on a 306 s16 petrol? also will this disable the immobiliser?1 more, can you unlock 406 8v turbo ecu? chris. ________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
![]() Regular ![]() Location: Gothenburg Registered: 23 May 2009 Posts: 131 Status: Offline |
Post #37
eddy_gti6 wrote: will the unlocked gti6 ecu work on a 306 s16 petrol? also will this disable the immobiliser? 1 more, can you unlock 406 8v turbo ecu? chris. A unlocked 8v ecu would be nice ![]() ________________________________________ Peugeot 306 Dimma CoupƩ. |
Post #38
eddy_gti6 wrote: will the unlocked gti6 ecu work on a 306 s16 petrol? also will this disable the immobiliser? 1 more, can you unlock 406 8v turbo ecu? chris. No is the answer to all of those questions, sorry. ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
Post #39
peder_306 wrote: eddy_gti6 wrote: will the unlocked gti6 ecu work on a 306 s16 petrol? also will this disable the immobiliser? 1 more, can you unlock 406 8v turbo ecu? chris. A unlocked 8v ecu would be nice ![]() Sorry, I can only do the Marelli 1 AP's as found on the GTi-6, Rallye etc. Cheers Rich ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
Post #40
Friday morning bump ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
![]() Junior User ![]() Location: Dunstable Registered: 25 Aug 2008 Posts: 61 Status: Offline |
Post #41
Hi Rich,How much is it these days? Lots of prices up there /\ Keith |
Post #42
Still £60? |
Post #43
masekwm wrote: Still £60? Replied to via PM. ECU received, should be on it's way back to you tomorrow. ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
![]() Regular ![]() Location: Dorking, Surrey Registered: 17 Aug 2010 Posts: 122 Status: Offline |
Post #44
Rich, i need one done please, whats the turnaround?________________________________________ www.krisb.co.uk |
![]() **BAD SELLER** ![]() Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Post #45
Kris your probs best speaking to lynx direct as rich is away till mid week |
![]() Regular ![]() Location: Farnham Registered: 23 Aug 2007 Posts: 294 Status: Offline |
Post #46
Hey Rich.I'm in need of an unlocked ECU. I can either buy out right or i have one here that can be unlocked. Which ever is easiest / Cheapest Thanks |
Post #47
springs wrote: Hey Rich. I'm in need of an unlocked ECU. I can either buy out right or i have one here that can be unlocked. Which ever is easiest / Cheapest Thanks No worries - will PM you. ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
![]() NV motors ![]() Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
Post #48
Rich can i have one please ![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
Post #49
mabgti wrote: Rich can i have one please ![]() Sure, do you have one for me to unlock, or did you want to buy one outright? Cheers Rich ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
Post #50
out right mate.. txt me your details please. Would help if you could socket it for me to![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
