displaying posts 1 to 25 of 69
Pages (3): [1] 2 3
Author Subject: Uprated Main & Big-end Bearings
rich_w
[b]
Contact Details:
07732 822546
Posted 6th May 2009 at 19:43
rallyerallye
Can you do a set of big end bearings on there own without the mains? If so how much? Thanks
Posted 14th Aug 2009 at 16:48
rich_w
Yes,
Contact Details:
07732 822546
Posted 14th Aug 2009 at 17:24
24seven
Can you supply these for the XU9J4 as well?
Posted 14th Aug 2009 at 17:28
MCH_GTi6
formerly mch
are you going to continue to stock these? as I'm looking to rebuild my spare engine in the near future (not too long hopefully)
Team Moonstone� Ph3 GTI6
Team Rallye
rallyerallye
Excellent. I will hopefully get away with just bearings. Is it possible to come and collect some as I am not to far way? If they have been changed for undersize ones will they be marked or will I have to get the crank measured?
Posted 14th Aug 2009 at 17:44
rich_w
Yes can do the XU9J4 also Yes
Yes I will always be able to supply these - I have been appointed a UK re-seller since Longmans bit the dust.
As for sizing - if they are undersize, it will tell you on the underside of the shell, and say -0.3, -0.5 etc.
Smile
Contact Details:
07732 822546
Posted 14th Aug 2009 at 18:02
rallyerallye
Thanks. I will have a look tomorrow & let you know what I need.
Posted 14th Aug 2009 at 19:10
24seven
Good stuff. I'll be rebuilding my spare Mi16 engine as part of a uni project so will be after some of these then. Do you supply other components like piston rings, rod bolts and similar?
Posted 14th Aug 2009 at 20:34
is this main bearing ok??:
loks worse than it feels with a finger.
are they standard size, is it possible to change the big ends while the crank is in the engine and engine in the car?
andy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 5th Mar 2010 at 03:51
rallyerallye
Andie+Katie, It is possible to do them in place! I have just stripped mine to check, they all seem ok but I am going to replace them anyway as im that far in!!
Posted 18th Aug 2009 at 18:32
indeed, its a bit illy to strip that far and not replace them, you can change the big ends, but its quite a lot more involved to change the mains bearings for which I would take the engine out and upend it on a stand.
Posted 18th Aug 2009 at 18:40
why cant the mains be changed 1 by 1 with the sump off?
Posted 19th Aug 2009 at 07:03
pete_rallye
Because you have to take the crank out, and you have to take all the main bearing caps off to take the crank out. Its not that much more work than the big ends, most of the stuff will have been taken out already.
Lap of the 'ring
Posted 19th Aug 2009 at 12:51
nick205gti6
you dont have to take the crank out. I've just changed pistons and cylinder head in the car after the cambelt slipped and a valve mashed a piston.
1990 205 GTI-6
Posted 19th Aug 2009 at 14:06
Rich E Forum Admin
The question referred to main bearings not big ends, and you do need the crank out to change the mains Yes
Posted 19th Aug 2009 at 14:20
the mains can be changed on some engines though while crank and engine are still where they live, cant they??
im sure when i worked at the garage i can remember it been done?
Posted 20th Aug 2009 at 02:37
24seven
You can only change the outer halves (under the caps) of the mains with the crank in place. The other halves are under the crank.
Rich, My Mi16 is being rebuilt no instead of later, so am interested in a set of these. What range of oversizes can you supply them? My crank is being reground though I believe it's not really suffered too much damage and doesn't need much more than a polish out.
Do you supply piston rings as well? I may need some advice on using new rings with my liners, if you don't mind me picking your brains.
Guy
Posted 7th Sep 2009 at 04:57
You could do it with the crank in place (Not easy but it is possible to push out and rotate the old shell aroud the crank and out the other side)but there would be no sure way of checking the bearings for ovality once the caps had been torqued down. If you just want to fit them and take a chance that the clearances are even all the way round then thats fine, but it's a big gamble and for the small ammount of extra work required to get the crank out at that stage it's not really worth the risk.
Posted 7th Sep 2009 at 05:27
turbowagon
rich can you pm me what uprated parts you can do for a 406 sri turbo engine? think bottom end may be same as gti-6? just blown my engine up
slowest project car ever.com
Posted 7th Sep 2009 at 14:47
rich_w
Hi mate, historically i've not supplied much for that engine. PM me with exactly what you need, will see what I can do.
Wink
Contact Details:
07732 822546
Posted 8th Sep 2009 at 04:49
they're pretty much identical to the 6 bottom end wise, just another iron block XU10 Smile
Posted 8th Sep 2009 at 05:00
rich_w
Standard size and -0.3 undersize mains and big-ends are in stock.
I also have sets of thrust washers in stock.
Cheers,
Rich.
Contact Details:
07732 822546
Posted 27th Oct 2009 at 15:57
chris with a pug
rich are the thrusts you have all standard size?
Posted 27th Oct 2009 at 23:16
rich_w
Yes - all the thrust washers I have are standard size.
It's very unlikely you will need anything else.
Smile
Contact Details:
07732 822546
Posted 25th Nov 2009 at 21:39
Pages (3): [1] 2 3
