this way click here
or this way
any ideas
Ph2 Black GTI 6!EX black 6 owner
| Author | Subject: Best way to lower rear end????? |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,310 Status: Offline |
right after seeing several ways of doing this im confused as f**k as to how to do itthis way click here or this way click here any ideas ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
I went with the first one and it worked just fine on mine ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
they're both the same method ![]() one small detial is incorrwect in the first, the seal clearance should be o.o5mm not .5mm. I would highly reccomend you get hold of Matt Evans (M@tt) or Chris penrose (309pug) for a dummy damper to set the height, and Tom Fenton for a Custom made torsion bar puller. Also worth noting, the stock damper bolt measurement is 330mm on the 20 mm gti torsion bars. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cress87
Seasoned Pro Location: Norwich Registered: 30 Mar 2007 Posts: 11,360 Status: Offline |
Paving slabs in the boot. ________________________________________ ![]() You feed beefburgers to swans. ![]() I may have been speeding Mr Policeman but [a] I live for the 306 and [b] did you see that dog? omfg |
got toms tool on order. so you reckon its best for me to get the dummy shox also? hmmm how much?________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
sacko_gti6
Seasoned Pro Location: Kent Registered: 12 May 2008 Posts: 4,783 Status: Offline |
Click Me________________________________________ Build Date - 30 September 1997 - Tuesday's car..is full of pace?![]() |
quote: . Paving slabs in the boot. ________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
hovis16 wrote: got toms tool on order. so you reckon its best for me to get the dummy shox also? hmmm how much? |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
in most cases at laest one of the torsion bars will be seized into the arm.. i have found the nly way to shift the bar is to remove the whole arm and prs the bar out, usually a seized bar will come free at about 0.8 tonne force. If you want to lower 30 mm the best way is to leave the torsion bar in the arm, tap arm outwards to free the inner spline and the just adjust it one spline, this also measn you will have the height bang on the same both sides. |
hmmmm interesting that is,so rotate the splines in which direction?________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
doesnt matter which way you turn them, just turn them till you find the one that slides in nicely.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dave2005
Regular Location: Middlesbrough Registered: 02 Feb 2009 Posts: 349 Status: Offline |
jonnie205 wrote: in most cases at laest one of the torsion bars will be seized into the arm.. i have found the nly way to shift the bar is to remove the whole arm and prs the bar out, usually a seized bar will come free at about 0.8 tonne force. If you want to lower 30 mm the best way is to leave the torsion bar in the arm, tap arm outwards to free the inner spline and the just adjust it one spline, this also measn you will have the height bang on the same both sides. will the inner spline come out that easy |
Rich E
If you're going to do it that way then get a copper hammer and smack the trailing arm until it does!________________________________________ Rich |
jonnie205
usually the bar will seize in arm not the inner end. You need to lower on the same set of splines as they are different sizes in the arm and in the other end, ie lower both arms on the inner spline or both arms on the arm spline.If they are seized i use a porta power to push the arm off. Hitting the arm with a hammer will require some very hard hitting and can knacker the arm. Porta power can give me 10 tonnes of force and no damage whatsoever |
hainesygti6
Junior User Location: Abingdon Registered: 31 Aug 2009 Posts: 96 Status: Offline |
Mine came out from the arm end on my phase 1, but i only moved it one spline so i might lower it one more.________________________________________ Refurbing Cyclones Black work in progress!Phase 2 rear light conversion to go on. |
darkgti6
Seasoned Pro Location: Bracknell Registered: 07 Jun 2008 Posts: 1,361 Status: Offline |
hovis16 wrote: got toms tool on order. so you reckon its best for me to get the dummy shox also? hmmm how much? What are you going on about I have your Tom fenton torsion bar puller I will drop it off for you if you want and your welcome to borrow my dummy damper as well let me know when you need them, Chris. ________________________________________ Team Peugeot Sport 308 Gti�Black T'99 Gti - may she rest in peace - written off in a shunt on the A329m |
haha this is OLD chris somebody brought it up hahahaha still p*ssed?________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
aknight
Regular Location: Stilton Registered: 12 Dec 2002 Posts: 348 Status: Offline |
Use the car to more house a few times.. soon makes it sag down ________________________________________ Team 330mm.Team Rallye. |
mjstones
Seasoned Pro Location: straight outta compton Registered: 16 Oct 2007 Posts: 1,233 Status: Offline |
cress87 wrote: Paving slabs in the boot. lol, i had a mate who did that with his rover ti, lowered like f*ck at the front and a couple of slabs in the boot. classy. ________________________________________ Never underestimate the power of De-Nile.Friday afternoon car, built in France.... ![]() 306gti6.com Stickers available, pm me for details. or email MjStones83@hotmail.com Sticker Thread with pics |
