displaying posts 1 to 25 of 37
Author Subject: neg camber
dorkvonwaterfall
how to make neg camber in the front?
cheapest way off course Happy
evt homebrew?
have bilstein coilovers
Posted 1st Mar 2009 at 16:45
Longer wishbones Wink
Or, longer wishbones, and sleeved struts:
Whistle
If you're on coilovers a set of adjustable topmounts will get you a little, provided you have enough thread on the top of the dampers to fit them.
Posted 1st Mar 2009 at 16:50
dorkvonwaterfall
where to get the parts?
Posted 1st Mar 2009 at 16:52
monkeyman
Original poster is from Denmark btw.
Forum Search Clicky
Posted 1st Mar 2009 at 17:46
The first, at the minute the only places I know are Special Tuning, Voisin Racing and KRS.
The second you'd have to have a set of special coilover bodies made for.
The third you can get from Compbrake, KRS, ST, and probably many other.
Posted 1st Mar 2009 at 20:14
soton_s16
Would they be the ones that are over
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 4th Mar 2009 at 02:30
Posted 4th Mar 2009 at 17:41
dorkvonwaterfall
how about making the holes in top bigger?
btw, what means "sleeved struts"
Posted 9th Mar 2009 at 00:08
midlife
See here, KAD 205 adjustable top mounts off ebay
Team 330™Cool
Team "no front end or engine"
Posted 9th Mar 2009 at 05:26
Sleeved struts - use a thinner strut casing than normal and put an offset sleeve in the hub - you can only get a little bit extra this way though
Posted 9th Mar 2009 at 07:50
dorkvonwaterfall
@midlife
looks great, but wont work for me, cause im not allowed to weld in the plate (MOT doesnt allow that here) and i also have to be able to put in the original suspension for MOT....
Posted 9th Mar 2009 at 11:18
Denis
The other option is to machine the hole in the hub at a slight angle and make a sleeve to fit normal strut. You can go up to about 1deg
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 9th Mar 2009 at 16:37
gti6loon
russian guy wrote:
Practically you can not move standard top mounts with standard spring pans as they are very close to the body as is.
Id say realisticly most of us who are looking to mess about with the camber are probably using coilovers anyway.
Steve
Steve
Planning a ring trip? Why not stay at Hotel Burgstube
Posted 9th Mar 2009 at 16:47
dorkvonwaterfall
how much camber do these give?
http://compbrake.co.uk/shop/product_info.php?cPath=12&products_id=3573
Posted 15th Mar 2009 at 23:49
sacko_gti6
Do it like this
Build Date - 30 September 1997 - Tuesday's car..is full of pace? Wink
soton_s16
I take it the above top mounts from Compbrake work with standard struts? No need to go to coilovers.
Posted 16th Mar 2009 at 19:46
midlife
Think you will find you need coilovers for any movement of the strut top.
I Use these click here
They are
Team 330™Cool
Posted 16th Mar 2009 at 22:28
dorkvonwaterfall
They are
Posted 16th Mar 2009 at 22:54
vts_tibi
what do you guys think of this:
Monroe Magic Camber
a simple camber adjuster bolt, and it's capable to adjust +/-3
VTS
best 60' : 2.272
Team Trackday™
Posted 16th Mar 2009 at 23:28
dorkvonwaterfall
cant use them on a 306.....
Posted 16th Mar 2009 at 23:24
vts_tibi
why so?
VTS
best 60' : 2.272
Team Trackday™
vts_tibi
the top bolt is replaced with this magic camber bolt, and the bottom bolt remains in place
the top hole doesn't need modification, as for example the excentric part of the Monroe bolt is 10mm, whereas the bolt itself is only 8mm
and the original is 10mm also
VTS
best 60' : 2.272
Team Trackday™
Posted 16th Mar 2009 at 23:32
dorkvonwaterfall
cause the struts arent mountet in a lower bracket, there just put into the swivel hub
Posted 16th Mar 2009 at 23:34
gti6loon
Go and take a front wheel off a 306 and have a look...all will become clear mate.
Steve
Posted 16th Mar 2009 at 23:45
vts_tibi
Doh sorry... forgot how our suspension looks like... Roll eyes
VTS
best 60' : 2.272
Team Trackday™
Posted 16th Mar 2009 at 23:59
