Author Subject: Plate LSD's, Would anyone be intrested in a Group Buy?
miles
As topic title, Now that Gripper are back in business, I say that but really they have expanded I can offer a good price on these if we get 5 people intrested, RRP is
www.pugracing.com
Posted 13th Jan 2009 at 05:49
does the box have to be removed and stripped to fit a new diff?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 13th Jan 2009 at 23:07
puglover Banned!
no not really driveshafts out, and technically can be done with box attached to engine.
Posted 13th Jan 2009 at 23:10
mabgti
NV motors
Might have to remove gearbox mount to drop it a littleYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 13th Jan 2009 at 23:31
cool!!
Posted 14th Jan 2009 at 00:42
smegal
Interested but its quite alot to shell out in one go. Will keep watching and may be in funds dependent.
Would they be alright for normal road use?
Ex SC-6
Now in a Megane R26
Posted 14th Jan 2009 at 01:32
bono
They are ok for normal road use as long as you get them set with the correct preload/ramp angle and use the correct diff oil.
///M5
Posted 14th Jan 2009 at 02:18
hi what do you mean by setting the preload/ramp angle?
tthanks
Posted 14th Jan 2009 at 02:39
puglover Banned!
its something to do with the power distribution between each of the front wheels. 80/20 75/25 etc etc I don't think they are supposed to be very good on the road, will clonk on tight turns, although it will actually make it a 2 wheel drive car which can only be a good thing.
Posted 14th Jan 2009 at 03:13
bono
From my experiences, the ramp angle is to do with the way the diff locks depending on whether accelerating or decelerating.
45/45 means it locks both on deceleration and acceleration, this is not good in a fwd car as the diff will lock when turning into a corner unless you are accelerating, this makes it hard to turn in.
Better is to have a 30/60 so the diff is less likely to lock on deceleration and more like to lock on acceleration.
This means you can turn into the corner and then stamp on the power which will put power to both front wheels without spinning the inside and understeering.
preload is to do with the grabbiness of the diff. Essentially you would most likely want the minimum setting for road/light track use. setting it too hard can cause the diff to snatch violently.
The settings are very important as if they are wrong they will screw up the handling entirely and make it very shit to drive. But when setup properly they are amazing.
///M5
Posted 14th Jan 2009 at 03:40
f*ck me, i never knew that you can adjust them!!
i just thought they was plug n play!!
didnt the rs turbos have them fitted as standard?
Posted 14th Jan 2009 at 14:34
bono
the quaife ones i don't think you can, but plate diffs you can take apart and swap stuff out.
Same as you would with most things like engines, gearboxes etc.
What's an rs turbo?
///M5
Posted 14th Jan 2009 at 17:16
fletch
Track Head
I would have thought you'd need to drop the subframe a little?
Posted 14th Jan 2009 at 17:17
quote:
What's an rs turbo?
lol thats a question like "accrington stanley, who are they"
ford escort rs turbo 1.6 turbo. 137 bhp standard, getting old now.
Posted 14th Jan 2009 at 17:39
kman1600
Hi,
Having run both a gripper and a Quaife I wouldn
Posted 14th Jan 2009 at 18:22
Viscous diffs are rubbish.
Do you not have to service these pretty regularly Miles? Obviously they are the ones to use on track and rallying, but are they practical for say a 10k a year road car?
Posted 14th Jan 2009 at 18:43
midlife
How would a Gripper diff compare to a Kaaz diffDunno
Cool
Team 330™Cool
Team "no front end or engine"
Posted 14th Jan 2009 at 19:02
bono
You have to drop it a lot, its a complete arse of a job. Much easier to take the box off and do it that way. I was told you could do it by 'just loosening the subframe' complete utter bo***cks. You can on a 205, NOT a 306.
Who are accrington stanley?
///M5
Posted 14th Jan 2009 at 19:54
miles
Servicing is always a hard one as it depends on how much use it get's, Much like a clutch, some last 20k other's last 200k,
But from experance my last one did 5 season's of racing before it went back, not sure what was changed as I sold it,
The reason I tend to offer Gripper or Tran X is they are both Midlands based and very helpful, not imported and supported by a importer so if any parts out of stock they cannot make it only order it, The service cost's are only around
www.pugracing.com
Posted 15th Jan 2009 at 03:47
Football ClubThumbs up
Posted 15th Jan 2009 at 16:29
kman1600
Hi,
My Gripper did 2 or 3 seasons in my car (not a 306 admittedly, or even French for that mater!!!) and never gave me a moments concern. I sold the box to an avid track day doer and I know he used it for at least a couple of years without looking at it. I lost touch with where it went after that. Although that
Posted 15th Jan 2009 at 20:08
puglover Banned!
i can get tranx diffs at
Posted 17th Jan 2009 at 18:27
cjslator
Posted 1st Mar 2010 at 17:34
puglover Banned!
not anymore sorry
Posted 1st Mar 2010 at 21:24
cjslator
Can you still supply them though? If can you PM me a price please
Posted 1st Mar 2010 at 22:04
