Shit French electrics.
All temps normal, ideas?
| Author | Subject: Flashing STOP light! |
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
Came on toward the end of my journey ![]() Shit French electrics. All temps normal, ideas? |
justinaccurate
Seasoned Pro Location: Cov Registered: 29 Apr 2006 Posts: 14,425 Status: Offline |
Flickering or flashing regularly?When my stop light came on intermittently recently it just needed the brown sensor on the thermostat re-plugging |
fletch
Flashing. Brown sensor is disconnected iirc. |
aaron6
Mine came on for no reason and just went away about 5months ago.1 month later the head gasket went, possibly because of thermostat sticking. Change the sensor and maybe for the sake of ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
tobeski
Seasoned Pro Location: Broadstairs Registered: 14 Apr 2005 Posts: 1,150 Status: Offline |
Mine done it recently, was the fan controller unit (Bitron) that caused it as it had got wet after going through a puddle. Also done it before when the Brown sensor packed up. Could also be the thermostat, worth investigating. ________________________________________ Now rollin' in a 182FF |
fletch
Doubt its the thermostat as temps are normal, I'm guessing fan controller sending dodgy signal to ECU. Cheers |
aaron6
fletch wrote: Still may be worth checking it.So iv been told you just take it off and dip it in boiling water,if it opens fully its fine,if not,its f*cked.worth checking id imagin.Wont cost anything other than some coolent to top up and bleed back in.Doubt its the thermostat as temps are normal, I'm guessing fan controller sending dodgy signal to ECU. Cheers ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
dave
Seasoned Pro Location: Larkhall Registered: 18 Apr 2007 Posts: 2,907 Status: Offline |
Check the oil level |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
This on your new engine Matt?Checked the oil pressure switch connector etc? ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
fletch
rich_w wrote: This on your new engine Matt? Checked the oil pressure switch connector etc? Nope other car. Haven't checked OP switch no. I've never seen the STOP light flash before, usually it stays fully illumninated. |
fletch
dave wrote: Check the oil level ![]() Good shout, all good according to the dash sensor but will check manually. |
carisma306
Newbie Location: milton keynes Registered: 21 Jun 2007 Posts: 46 Status: Offline |
did anyone find out what this was as mine is doing this now and the fans start as well when you start the car up? any help ![]() ________________________________________ |
lwgti-6
Senior User Location: Nottinghamshire Registered: 27 Oct 2008 Posts: 906 Status: Offline |
I've just been out in the car now and had the same problem....(flashing on and off quite fast)I'm assuming its the brown sensor on the thermostat housing not being plugged in correctly as the fans kept cutting in and out on their own.. Anyone else confirm this? ________________________________________ EX Bianca 6 owner,Now drives: Octavia vRS |
fletch
Im convinced its fan related, broke the car in the end, so didn't fully investigate. |
lwgti-6
fletch wrote: Im convinced its fan related, broke the car in the end, so didn't fully investigate. Ok mate, Just hope my filter hasn't sucked water up and f*cked something up ________________________________________ EX Bianca 6 owner,Now drives: Octavia vRS |
