Author Subject: stupid bolts came loose
pedro_de_la_cruz
the 2 bolts that hold the fuel rail to the inlet manifold have worked themselves loose while driving and are gone
the car doesent want to start unless fuel rail is held down by hand so does anyone know the size of the bolts
looking at the holes id imagine its a 10 or 12mm bolt, bolts from any supplier will be fine i take it the pug ones arnt magic or anything LOL
cheers
*R.I.P Pete Sims*
Posted 1st Dec 2008 at 06:20
smighall
Smeg-all
IIRC M6 bolts 10mm hex head
Meh
Posted 1st Dec 2008 at 12:45
sacko_gti6
Speak to swampy, im sure he could sort you out with the correct nuts/bolts
Build Date - 30 September 1997 - Tuesday's car..is full of pace? Wink
Posted 1st Dec 2008 at 13:18
pedro_de_la_cruz
ok so i found bolts but now theres an intermittent starting problem...car seems to want to start fine when bolts are loose but when tightened so the fuel rail cannot move around it doesent want to start
how tight should the bolts be?
*R.I.P Pete Sims*
Posted 6th Dec 2008 at 15:42
i have had this but it wasn't rail related in the end
i have ran my car with only one bolt on the rail for yonks and even with no bolts temporarily. i don't think this would cause a big problem aslong as the injectors were seated properly
Posted 6th Dec 2008 at 16:54
paul_gti6_uk
Pedro. Since we talked about the whole starting up thing I have been keeping an eye on mine. When it has been left at work in the cold weather recently it has been very very lumpy on startup! definately different to when I had standard cams. A small blip of the throttle is helping startup and sometimes i have to help it hold its revs for a few seconds then it is ok.
I'd think with a BTCC manifold and TB yours shall be flowing even more air so maybe it is something to do with this?
You couldn't also be affecting an earth point of some kind when doing up the fuel rail bolts could you?
China Blue 306GTI-6 Big grin Ph3
Team Now Bikeless Sad
Posted 6th Dec 2008 at 19:09
pedro_de_la_cruz
it starts eventually just takes a few times of letting the fuel pump prime, blipping throttle on start up doesent seem to help just get quite a bad misfire
once started it runs absolutely fine idle isnt even that lumpy, even through last week when its been freezing cold so im pretty sure its fuelling related
ill try an ECU reset and see if i get any joy
*R.I.P Pete Sims*
Posted 6th Dec 2008 at 19:47
mr swampy s16
**BAD SELLER**
Yeah m6 by 10mm
i supply socket cap ones
but any m6 bolt of right length will be fine
Posted 6th Dec 2008 at 19:56
asim_pug306
Thread revival here... What length should these bolts be??
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 26th Jul 2012 at 22:18
servicebox says:
6922 97
x02
SELF-TAP SCREWS
DIAM 6 X 1.00 - 20
70p each.
Posted 26th Jul 2012 at 22:28
smegal
Check the wires to the injectors
Ex SC-6
Now in a Megane R26
Posted 26th Jul 2012 at 22:57
asim_pug306
Welshpug... You di man! Thumbs up. Is that dealer price?
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 27th Jul 2012 at 04:10
yeah, and note they are 20mm long, not 10mm said by Mrs Wampy Wink
Posted 27th Jul 2012 at 08:37
