Author Subject: Broken Battery Connector
black 6
Hi All, I overtightened my battery negative terminal and it has snapped, can you replace them. Any ideas? Thx
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 19th Nov 2008 at 04:24
birk
Yes
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th Nov 2008 at 04:29
black 6
birk wrote:
Yes
Is that you can replace them, is it easy, are they crimp connectors so to speakLOL
Posted 19th Nov 2008 at 04:30
birk
Yea, you can replace them, i think i might have one lying around you can have for a few quid.
07889376885
Dan
Posted 19th Nov 2008 at 04:37
black 6
Thumbs up If you do please send me a PM, cheers Dan.
Posted 19th Nov 2008 at 04:38
birk
yea mate, will do. will have a look 2moz or thursday. Smile
07889376885
Dan
Posted 19th Nov 2008 at 04:43
jungle jim
You can replace them as birk said...
The one I replaced was soldered on though so was a bit of a b*tch to remove. we dremeled it off in the end. And replaced with a motor factors battery terminal.
200+ secret squirrels hiding under the bonnet with 4 wide mouth frogs...
Posted 20th Nov 2008 at 16:04
black 6
Cool thanks Jim Thumbs up
Posted 20th Nov 2008 at 16:08
stu
Major thread Bump.
My negative battery terminal has decided to fall to bits. Dry
Can anyone tell me how easy it is to remove it from the wire? How is connected? Would I be better off cutting the wire and then getting a new connection or do I need to replace the whole wire?
I had a look on Servicebox to see if the terminal was available separately but it seems you have to buy the whole cable, which at ~£40 plus VAT seems a bit expensive to me. Blink
Any help would be appreciated. Thumbs up
Posted 8th Apr 2010 at 20:13
black 6
Get the old one off and get a motor factors terminal which is attached via a clamp.
Posted 8th Apr 2010 at 21:21
stu
So did you just cut the wire or does it just pull off?
mr swampy s16
**BAD SELLER**
Cut the wire.
Then cut some of the cover back and push thru the new clamp
Posted 8th Apr 2010 at 21:42
blaze wip
I took one from a d turbo (i think) in a scrappy's
Twas a tad shorter on the body earth lead though so i just made a new earth point on the bulkhead.
Block to battery was fine.
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 8th Apr 2010 at 21:48
