Author Subject: clutch pedal sticking
topshot_2k
hi,
clutch pedal is sticking the clutch seems fine its the last inch or so it doesnt return to its normal position. now i have checked both the springs and cleaned/greased it all and WD40 the cable but its even worse!!!
any ideas? i can get into gears ok but i have to 'flick' the pedal up to its normal position with my toes after every gearchange!!!!!
Owner of a Nile Phase 2 GTI-6 & Impreza WRX Smile.
Posted 15th Oct 2008 at 00:01
steve h gti-6
Mine did that for a while until I reset the clutch cable. undo the the end at the gearbox and push it back and forth and that should reset it IIRC.
If it wont it looks like a new cable im afraid
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 15th Oct 2008 at 01:18
306er
mine did the same till i did the same as above
diablo 6 black 6 China Blue GTI 6
Posted 15th Oct 2008 at 01:27
chas
Mine's started to do this a little since I fitted the new cable. I noticed that without the cable, the pedal is spring assisted? I guess I need to clean the spring and lube up the moving parts?
Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed
1974 Triumph Stag
1989 Peugeot 205 GTi 1.6
2003 Alfa Romeo 147 JTD Lusso
2005 Mondeo Ghia X 3.0 Estate LPG
Posted 15th Oct 2008 at 01:48
steve h gti-6
Yeah and if the above dosnt work, push the cable in and out when its not clipped underneath on the subframe as well too, its only held by a push clip.
"Gotta Love The 6"
Posted 15th Oct 2008 at 01:52
mechanical_repairs
Remove the spring on the pedal, it was a recall when they were more or less new.
Carl
topshot_2k
thanks for the replies, i have tried cleaing/lubing everything, that hasnt cured it!
Carl you mean the spring nearest the pedal rubber? is it worth replacing or just remove it?
Posted 15th Oct 2008 at 02:54
topshot_2k
drove it work today and its worse, seems like i really have to force the pedal down to change gear, the bite point is about 2-3cm from the lowest point of the pedal is this too low?
really hard getting into reverse aswell, keeps crunching Sad
Posted 15th Oct 2008 at 23:30
clutch last lifes symptons??Whistle Whistle
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 16th Oct 2008 at 00:25
topshot_2k
i dont think it is, theres no judder/slipping and bite feels like it always has, its just the damn pedal/cable etc wont return to their normal position.
Have cleaned all the springs etc but still no joy. Will take the cable off tomorrow and grease it up/clean it and see if that sorts it
Posted 17th Oct 2008 at 15:45
gingec
As Carl said, remove the spring. He took mine off a year ago and all is well.
Posted 17th Oct 2008 at 17:51
topshot_2k
will give it ago tomorrow Thumbs up
Posted 17th Oct 2008 at 17:54
gtisid
remove the spring from the top of the clutch peddle when faulty it makes the clutch peddle stick and makes the peddle sit to high. i think the clutch is on the way out. gets stiff a new cable is a temp fix but it will go the same as the old one in a short time . fitting a new clutch and cover will make it smooth as
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 17th Oct 2008 at 23:35
petegti6
Aye, new clutch FTW LOL
Cress87 wrote:
This place is getting beyond a joke. There's been an enormous influx of bellends signing up recently
Team 205 1.9 GTi
Team: Hmm™
Posted 18th Oct 2008 at 04:07
iplay
Lubricating the clutch lever arm might help.
Posted 18th Oct 2008 at 05:40
gaz likes shmeat
sorry to bring this thread back to life but it is relevant as I have the exact same problem...
Can anyone confirm, does this spring simply need removing or replacing? From what I can make out about, it just looks like it need removing all together?
Posted 10th Aug 2010 at 17:28
berger
Removing.
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 10th Aug 2010 at 19:30
gaz likes shmeat
smashing ta
Posted 10th Aug 2010 at 19:52
Rimrod
Again sorry for bringing the thread back to life but I have the same problem.
Where exactly is this spring that needs taking out?
Posted 6th Jan 2017 at 15:56
on the side of the pedal
Posted 6th Jan 2017 at 15:58
Rimrod
Thank you.
Posted 6th Jan 2017 at 16:13
mellowr1
Mine did that until I got new cable fitted. Perfect after
Posted 8th Jan 2017 at 18:58
Kenan
Just went to take mine off and someone beat me to it. So clutch cable it is then . . .
Posted 8th Jan 2017 at 21:19
Good luck with that it's a cvnt of a job
Posted 8th Jan 2017 at 23:21
fatlapit
clutch cable is probably the easiest job on the f**ker other than a shaft change
Posted 8th Feb 2017 at 10:20
