displaying posts 26 to 34 of 34
Pages (2): 1 [2]
Author Subject: overheating, only one fan comes on at 110!
james_geldart
you need to replace one fan, had this on mine.
Both fans should always kick in, slow speed at 97, high speed at 107.
get one second hand, as new fans are about
Recommends:
'mechanical_repairs' - Leicester
'miles' for suspension & Grp N/A goods
Baker BM Mounts
Posted 6th Nov 2008 at 16:10
jonnyvandijk
james_geldart wrote:
the reason one wont kick in at 97 is because you have one buggered fan,and they are on circuit, high speed are on a parrallel circut, hence why that one still works
Great stuff, I was wondering!!
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
danvilla2
Nice one James, will have a look on the weekend. Last thing, how do you go about getting to the fans? Can you get it from underneath??
Posted 6th Nov 2008 at 16:13
jonnyvandijk
Front bumper off, lights, slam pannel then can get to them. Thats why I haven't done mine yet!
The casing is hooked round the radiator and it is possible to get to them without removing the rad luckily. You have to prise the plastic though.
Posted 6th Nov 2008 at 16:17
alpha1ba
Same prob here re overheating at idle, unplugged brown sensor but neither fans come on! however at about 90ish the main fan kicks in for a while then p*sses off and doesnt come back on at all!!! any ideas? cheers (that almost rhymed)
Never argue with an idiot because they will bring you down to their level and beat you every time with experience!
Posted 19th Nov 2010 at 18:43
steve h gti-6
If you pull the brown plug you must have the ignition on to get any result ?
What should happen is ignition on, pull the brown sensor, both fans on slow speed then after a few secs they both go too high speed.
First check the connector on the bottom right, its a bit tight but twist it off, clean and then refit onto the housing.
Or I think your problem will be where the 3 relays are inbetween the fans at the front, pull the cover off and pull the relays out. You may find its all burnt out where the relays get pushed in. They tend to overheat, bit of moisture and then burn out taking the wiring with it Dohhhh...this is where you will need a new fan housing.
Failing that, pull one green relay out and do the ignition on and pull brown temp plug test. if nothing happens pull the other one out insted. You may just have a falty relay/s.
After that and still nothing you will have to test your fans, they are held in by 3 bolts thats it and run some current through them 12v IIRC.
Never rains but it pous with the fans LoL !
Hope that makes sense and helps matey.
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 19th Nov 2010 at 20:25
alpha1ba
Thanks for your reply Steve! FINALLY I got the fan to work after pulling the sensor out (which at the mo im more than pleased with!!!!!) would I be correct in saying that all I need to do now is replace the sensor as im almost on my way to pick one up from peugeot for no less than £32 + vat. Regards
Posted 19th Nov 2010 at 20:33
steve h gti-6
Yeah if there isnt any wiring burnt out behind and you have swapped over the relays etc and it works.
Forgot how much wonga they are, but im sure you could get them from EuroCar Parts IIRC
"Gotta Love The 6"
Posted 19th Nov 2010 at 20:48
supergti6
hey guys , my fans dont work at all as someone before me has fitted a manual swith to flick on when the car gets hot but that only controls one fan, so is always hot, and has made the rad go a few times and left me stranded, is there anything i could do? please would apprieciate some help!
Team work makes a dream work
Posted 20th Nov 2010 at 20:17
Pages (2): 1 [2]
