Author Subject: Rear Wiper - Wiping on its own
livy
it is
Posted 3rd Aug 2008 at 16:15
allesclar
just a fresh bump as i have the same problem.
opened the boot section with the wiper motor in it. Removed the blue relay and opened it up to see that it had corroded. Gave it a full on clean with wd-40 and then a slight sanding etc. Cleaned it up and re-installed it. still no joy.
i am presuming it has completley burnt out and will try the local scrap yards, i mean
Team allesclar ®
Posted 23rd Aug 2009 at 15:35
jpmatrix
I had the same problem. Water had leaked through the tailgatelock due to me pressure washing the car. I managed to fix the relay by prizing the cover off and cleaning the contacts out. I then wrapped it in some tin foil.
I cant believe these things are
Posted 23rd Aug 2009 at 22:36
fletch
Track Head
Posted 23rd Aug 2009 at 22:48
tvrfan007
I've got the motor and relay assembly on a P3 breaker if yous guys are stuck.
There are lots on ebay usually. Smile
As above I cable tied a u-bent plastic bag over mine.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 24th Aug 2009 at 02:47
