Author Subject: Radiator replaced - stop light is on dash?
ben8s8
I had a new radiator fitted recently, after the guy installed it a stop light appeared on my dash, the temps are normal when I drive [90 when warmed up] so do you think this is most likely just a sensor issue?
Thanks.
Posted 26th Jun 2008 at 16:41
probably the coolant level sensor, either not plugged in or stuck.
Posted 26th Jun 2008 at 17:40
ben8s8
Thanks, do you know where its located?
Posted 26th Jun 2008 at 18:02
ben8s8
Is it the far right one on this diagram?
diagram
Also would it be ok to disconnect all three of these sensors on that section to check them?
Posted 27th Jun 2008 at 16:23
roman
The blue one is the one to check and it would be okay to disconnect the others to check them also.
Saxo 1.5d - Daily driver Sad
Westfield SEi - Weekend warrior Devil
Places to buy parts/spares FAQ
Don't miss out on those e-bay items again.
Combidrive Ltd
Posted 27th Jun 2008 at 18:02
justinaccurate
you would probably get an air lock in the system if you took them out I would think Unsure
surely they are only temp sensors not level checks? Did phase 2 cars have an extra sensor on the rad? Mine has a blanking plate near the bleed point Unsure
Posted 27th Jun 2008 at 19:05
ben8s8
justinaccurate wrote:
you would probably get an air lock in the system if you took them out I would thinkUnsure
It's been two years and I've still not checked the sensors, a combination of procrastination and not really using the car.
So, would it be ok to remove the blue sensor without getting an airlock? The warning light came on after a mechanic changed the radiator over two years ago. Unsure I have read it could also be related to the fan. My car is a phase one and it has a manual fan operated by a switch to the right of the steering wheel.
Posted 2nd Jul 2012 at 15:55
