Author Subject: tip of the day
24seven
watch how you go about cleaning your stepper motor. I got away VERY lucky with this. The collar went in first and was big enough to stop the spring getting in under the valve, but soft enough to just bend and not cause any damage.
24seven has attached the following image:
Posted 27th Mar 2008 at 23:25
justinaccurate
Whoa was that the one I sent you? I suppose I should have made it more clear that I never used it.
How the hell did that happen? Was that just from pulling the shaft out when cleaning? I can see the sleeve and spring but wheres the end bit? Unsure
Posted 28th Mar 2008 at 01:05
midlife
Shock
Quick, rush out & buy a lottery ticket!!!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 28th Mar 2008 at 01:09
24seven
nah that's the old one I wrongly fitted. I think it wound itself out and crapped its pants. I still haven't received that one, so I think royal mail have lost it. the other peice was in the inlet manifold, fortunately it was too heavy to be sucked up.
Posted 28th Mar 2008 at 01:16
pedro_de_la_cruz
you took the inlet manifold off to clean the stepper? easier access but risk of accidents!
i just removed the breather pipe which i found had a leak where it joins the main induction hose going into the throttle body so going to upgrade to silicone me thinks
*R.I.P Pete Sims*
Posted 28th Mar 2008 at 01:17
justinaccurate
Bank holiday week is always a bit shite, sent it out first class on tue afternoon so hopefully be there tomorrow Unsure
Nah, he took it off to find the stepper Smile
Posted 28th Mar 2008 at 01:21
24seven
I replaced the plastic junk on my XS with a 6 manifold, not realising the difference in the stepper mounting. having put it back together (with shortened fuel rail mounts, bent a/c pipe and re-mounted rad top hose) and thinking it would all be hunky dory, it wouldn't idle. immediately I blamed the stepper, came here to read some FAQ's on cleaning the things and spotted a part that I was completely missing. went back to take the stepper out ready for the one justinaccurate sent, and found pieces of it missing. I recovered the phallus from the manifold using a magnet-on-a-stick thing, but couldn't find the other pieces so took the manifold off, and there they were. had a good look around the valve they were against and no damage has been done as far as I can tell. the collar is too big to have gotten into the seat, and the spring didn't get far into the throat because the collar was in the way.
Posted 28th Mar 2008 at 01:40
fletch
Track Head
Shock
Posted 28th Mar 2008 at 02:19
24seven
the car's back running again now and using the stethoscope I couldn't hear any unfriend;y noises from the head, so all's good. in fact the noisy exhaust-side tappet was very quiet listening to it this way, so I had a quick look around and found a loose spark plug. happy chappy!
Posted 28th Mar 2008 at 22:36
SteviePut
Is the car still OK mate?? Whistle
Posted 26th Nov 2011 at 22:59
justinaccurate
Laugh my ass off
Posted 26th Nov 2011 at 23:08
blue_haddock
holy thread resurection batman!
suck my plums!
Posted 26th Nov 2011 at 23:18
