Author Subject: Engine Breather Filter ICV
swifter gti6
I know the size required is 18mm but is it a male or female I need?
Wedding and portrait photography click here
Posted 27th Feb 2008 at 19:23
Rich E Forum Admin
With the standard pipe?
You'd want a male one. I couldn't find one so I used an 18mm female one and stretched it over the top (See here).
It was quite a tight fit though.
Posted 27th Feb 2008 at 19:25
swifter gti6
Yes the standard pipe.
I have just ordered one at 18mm. Should be ok click here
Posted 27th Feb 2008 at 19:35
lotek
ive got one of those piper x breather ones from halfrauds , it has metal instead of cotton in filter , would it be ok to use on icv?? i test fitted it and on idle its got a loud hissing noise where its sucking in air,
Posted 17th Sep 2008 at 20:49
joker
No, that's a breather not a filter.
Team 375 BHP Duratec™
Posted 17th Sep 2008 at 20:51
lotek
doh....... ive got a crank case breather instead of a icv filter. anyone wanna swap ??
Posted 17th Sep 2008 at 20:52
honestly3k
Thread revival but if i buy one of these breather filters for the ICV pipe thats half hanging off the inlet pipe will it cure my 'stalling when dipping clutch' and general feeling that it wants to die everytime i change gear and the revs drop sharply????
Did get the pipe glued into the inlet pipe a few weeks ago but its come off again and since felt very unstable whilst doing the above actions....
Basically will it function as normal with one of these filters on the pipe? Principle is the same i guess...
Posted 27th Jan 2011 at 04:19
clen666
will probably be that your ICV needs cleaning, or replaced if you're unlucky.
Put a filter on after to help keep it clean or try and get a replacement original pipe
Team 'unintentional rat look'
Posted 27th Jan 2011 at 12:44
honestly3k
Cleaned the ICV. Its just the pipe is half hanging off the inlet pipe.
I know its causing the unstability but just want to know if the people who have done this breather filter option have noticed their idle functioning normally after?
Posted 28th Jan 2011 at 01:07
Rich E Forum Admin
A split in this pipe won't directly affect the idle as it is before the ICV and the throttle body. It just means there will be a small amount of unfiltered air going into the engine.
I have a large split in this pipe on my car at the moment and it still idles perfectly.
Posted 28th Jan 2011 at 01:42
honestly3k
Generally it does idle fine.
Just when i dip the clutch the rev indicator plummets pretty hard and sometimes cuts the engine out.
Noticed an improvement when the pipe was sealed.
Will this filter work as a normal functioning pipe then or?
Posted 28th Jan 2011 at 02:45
clen666
yes a seperate filter should function exactly the same as the standard setup
Posted 28th Jan 2011 at 12:26
honestly3k
Finally a simple answer to a simple question, thank you!
Posted 28th Jan 2011 at 21:38
