Author Subject: injector clips
spiky
has someone got a pic of a close up of an injector in the fuel rail WITH CLIP, so i can see how the clip goes,
i put it on just now, how i thought it was (took off 8weeks ago)
and i tugged slightly on the rail and it came off all the injectors, so i guess i got it slightly wrong.
though cant see quite how other way they can go
i've been putting them on from the rear and pushing forwards
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 6th Jan 2008 at 21:21
spiky
sorted now Big grin
MY YouTube Videos'
Posted 6th Jan 2008 at 23:53
how did they go on in the end mate?
i take it the sticky out edge on it slided in the injector and the gap/groove bit sits iin the lipon the fuel rail?
ive been strugling to do mine today, did it but i was sure it should hold on to the fuel rail better than it did.
im going to try some new seals incase they are hard, but i dont think the paint i have just done it with is helping.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Aug 2009 at 02:21
spiky
i did put some new seals on and a little lubricant on the seals, all sorted, never leaked Big grin
MY YouTube Videos'
Posted 20th Aug 2009 at 02:36
did you clip it into the rail and the injector in the tiny gap??
now mines painted im thinking it could be to tight
Posted 20th Aug 2009 at 02:39
spiky
yeah, the injector goes in (upto first line i think) then the clip slides into the groove
MY YouTube Videos'
Posted 20th Aug 2009 at 02:42
hmm how do i explain this, does the bit that sticks out on the side of the injector have to meet up flush with the bit that sticks out on the fuel rail(near where the injector fits?
thabks spike
Posted 20th Aug 2009 at 04:58
ah realised how these clips fit yesterday, so simple cant belive i was strugling. i was trying to use them upside down.
Posted 21st Aug 2009 at 12:05
luke89
Picture please mate,just spent half an hour trying to get the mother truckers on with no luck.
Posted 31st Jan 2015 at 00:22
luke89
I realise thats 6 years ago by the way but it wasn't worth starting a new thread for.
Posted 31st Jan 2015 at 00:23
luke89
Any one?
Posted 4th Feb 2015 at 21:54
pete-gti
You don't really need the clips on them , I've never had none on mine for last 8 years never leaked
But will get picture for you :-)
Posted 4th Feb 2015 at 22:45
pete-gti
Posted 4th Feb 2015 at 22:50
You do need the clips...Yes
I had a rail leak because I'd powder coated it and the clips no longer fitted correctly.
Could have caused the entire car to go up in smoke as fuel was spraying everywhere! Shock
Posted 5th Feb 2015 at 13:06
I bet it wasnt as bad as swampy hoses though LOL
Posted 5th Feb 2015 at 13:14
pete-gti
Mine have never leaked , might order a set thow :-)
Posted 5th Feb 2015 at 13:16
luke89
Cheers! The one at the cambelt end is a right pain to get on.
Posted 5th Feb 2015 at 18:30
fatlapit
u dont need the clips they dont hold them in
Posted 5th Feb 2015 at 19:36
Think that's about all they do really
Posted 5th Feb 2015 at 22:20
pete-gti
Never had problem with them removed
Posted 5th Feb 2015 at 23:10
fatlapit
the inlet manifold keeps them at the angle. i run up to 4.5bar through mine they dont leak
Posted 6th Feb 2015 at 08:07
fatlapit
i think the bolts that hold the rail in keep the injectors in
Posted 6th Feb 2015 at 08:15
Manifold holds them at correct angle but standard injectors have a split spray pattern out the end. The clips stop the injectors turning round so they fire in the right direction I you know what I mean. If your running different injectors then doesn't matter at all.
And considering it's atomised into the passing air it hiukdnt really make much odds anyway.
Posted 6th Feb 2015 at 11:51
Indeed, could anything be as bad as those things...? Crazy LOL
Posted 12th Feb 2015 at 21:23
luke89
And considering it's atomised into the passing air it hiukdnt really make much odds anyway.[/quote
Yep that's what I was trying to get at, it stops them from spinning basically.
Posted 12th Feb 2015 at 21:36
