cheers
Coiloversexhaust
cambelt - done
clutch
headlights
knocks 'n scrapes
| Author | Subject: autodiagnostics light-powerloss..help!!! |
sionowz
Newbie Location: cardiff Registered: 24 Nov 2007 Posts: 18 Status: Offline |
hi, My car's been idling very rough recently, nearly cutting out then revvig to 2k revs. I thought it would be the stepper motor, but today the autodiagnostics light came on and i lost most of the car's power. The car currently 'chuggs' along like a tractor! Does anyone know what it could be? I'd rather try fixing it myself (no money after xmas!!) Any advice would be greatcheers ________________________________________ Coiloversexhaust cambelt - done clutch headlights knocks 'n scrapes |
charley says
Seasoned Pro Location: In the Wrong Registered: 26 Sep 2006 Posts: 1,282 Status: Offline |
Unfortunately it looks as though you will have to go to your Peugeot dealer to get a check/report done on your cars ecu, or do you know of a independant garage that might have the equipment to read the faults?I had to get a check/report done on my 307 for an ABS fault..........£51.34 not cheap Im afraid. You say "chuggs" does the 306 have a "safe mode" setting like later Pugs? ________________________________________ There,s a man with a mullet going mad with a mallet in Millets. |
big-6
Senior User Location: alnwick, Registered: 04 Nov 2007 Posts: 717 Status: Offline |
as far as im aware the gti6's have a limp home mode well the later ones at least what years is yours?________________________________________ White 6ex white 6 owner staying about for the crak ![]() team vag 1,8t |
sionowz
mines a 97 gti6....Ive been hearing a rough sound from the engine, a kind of metal on metal grind which i thought was injectors...dont know if that helps ________________________________________ Coiloversexhaust cambelt - done clutch headlights knocks 'n scrapes |
sionowz
also...when on idle the car shakes quite alot....when sitting behind the wheel, my whole body shakescheers ________________________________________ Coiloversexhaust cambelt - done clutch headlights knocks 'n scrapes |
tomoverton
Newbie Location: Brighton Registered: 22 Feb 2007 Posts: 33 Status: Offline |
Did you ever solve this fault, mine's doing the same. Cheers |
davedgti6
Seasoned Pro Location: whiston, prescot Registered: 28 May 2006 Posts: 1,651 Status: Offline |
this is the oldest bumped thread I have ever seen ________________________________________ Team Supercharged Gti-6™![]() |
tomoverton
Better than getting a bollocking for not using search and it saves me typing all my symptoms! |
