306 s16
| Author | Subject: s16 hesitation |
ashs16
Regular Location: Hatfield Registered: 08 Dec 2006 Posts: 104 Status: Offline |
Recently my s16 has become hesitant when i put the throttle down hard. So far i've changed the plugs, fuel filter and the coils and nothing seems to have changed, after having another look at the plugs it would appear that they arent getting enough fuel. Whats also weird is that if i rev the engine gently the it will accelerate right through the rev range without any hassle, its only when full throttle is applied that there is a problem. I've also noticed that my engine diagnostic light has started to come on now, is it possible to read a fault code from this. Any help would be much appreciated!! Or if anyone knows a good pug specialist in the chichester area let me know. cheers Ash________________________________________ 306 s16 |
rikky
avac diaphrams/solenoids or a lambda issue. might be ECU corrupt sector like mine was but i doubt this is your case as mine ran so incredibly shite________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
Wouldn't have thought it would be a lambda sensor issue as at full throttle it's supposed to ignore the lambda. Could be a lazy fuel pump or maybe a vacuum leak is affecting the fuel pressure regulator .________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
ashs16
My lambda is pretty new so hopefully not that, i thought it may be a vacuum leak as i can hear something hissing but couldnt pin point it. On the issue of fuel, i took my rocker cover of today ro replace the seal and when i removed my fuel pipe that goes into the fuel rail no fuel came out when i turned the ignition on, would fuel not come out as the fuel pump should have primed?________________________________________ 306 s16 |
rikky
vac leak would make it idle badly form experience?? mine had a leak right near the centre of the inlet at that T pipe and it would stall constantly and ECU light was on/off randomly. everything happened at once; lambda/ecu got faulty and airleak from damaged pipeworking putting the engine back innew diaphrams fixed the flatspot and funny running ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
dan_s16
My engines favorite place to develope a vacuum/air leak is along the back, the metal pipe that goes from the throttle body to the fuel vapour recicling solenoid. It snaps where it is fixed to the cam cover.That hisses and makes the car feel sluggish (also makes my car sound like it's got anti-lag on overrun ) I got a new pipe from pug only for it to do it again 6 months later so i've used a piece of fuel hose to join the metal pipe to the solenoid, no more leaks (touch wood).________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
the gunsons reader does the faults on the s16connects to the green plug by the ecu |
ashs16
cheers guys, at least ive got a few things to try now, fingers crossed.________________________________________ 306 s16 |
ad
Regular Location: High Wycombe Registered: 15 Aug 2004 Posts: 284 Status: Offline |
What about the throttle position sensor? That could be on it's way out. |
rikky
quote: My engines favorite place to develope a vacuum/air leak is along the back, the metal pipe that goes from the throttle body to the fuel vapour recicling solenoid. It snaps where it is fixed to the cam cover. funny you say that, i've just noticed mine snapped right now and rejoined it________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
avirally
Regular Location: South east Registered: 24 Jun 2007 Posts: 132 Status: Offline |
I have the same problem at the momment it seems that the car is overfuelling also thecooling fan comes on as soon as you try to start the car even though it is cold will that be related to the same problem ?________________________________________ 1995 306 maxi the best fwd car ever build |
mr swampy s16
Mine did the fan thing was a split wire a the join down the bottom of the radiator.I have a fuel rail, injectors, avac solenoid, diaphrams and pipe work all available. Also a pair of ignition amps, the big brown relay from behind the ecu and a very early ecu. |
