Author Subject: throttle cable
topshot_2k
Mine has snapped and i believe its the older type (goes over the top of radiator)
now can i still buy the old type from pug or will i have to convert to new shorter one that goes over the engine.
If i have to swap to a newer one do i need to buy any new clips/mounts etc? and ow hard is it to feed it though the bulkhead etc?
thanks
Owner of a Nile Phase 2 GTI-6 & Impreza WRX Smile.
Posted 28th Jul 2007 at 03:46
Welly Forum Admin
They are a universal kit so you can do either.
Vrs power!!
Posted 28th Jul 2007 at 05:23
mechanical_repairs
Easiest thing to do is buy the new cable and just remove the centre, then thread in the new centre and cut where needed, add the nipple and job done, should take no more than 10 minutes to do and means you dont have to wrestle putting the new sleave in the bulk head. Make sure your cutters are sharp or its a pain to get the nipple on with a frayed wire.
Another tip brought to you from Mechanical_repairs.
Carl
Posted 28th Jul 2007 at 14:43
roman
I always find that if I wind electrical tape a couple of times around where I need to cut, this helps give a better cut and keeps the strands from getting dammaged.
Saxo 1.5d - Daily driver Sad
Westfield SEi - Weekend warrior Devil
Places to buy parts/spares FAQ
Don't miss out on those e-bay items again.
Combidrive Ltd
Posted 28th Jul 2007 at 15:30
topshot_2k
Carl
cheers, i had to feed the shield through bulkhead as i had to cut this on side of the road and try to twist/tape the cable back together.Sad
all done now tough, although throttle pedal feels hard to push down. maybe its just because its new?
Posted 30th Jul 2007 at 20:34
rich-6
Its not binding anywhere is it? it should be easier to push down i'd have thought
Cool
RIP Pete Sims
Posted 30th Jul 2007 at 21:04
topshot_2k
not that i can see, although i have routed it along the top of the rad so i might change it to the shorter router,
in the bulkhead whats the round rubber ball with a hole in it for? i got a new one with the kit i bought but could not for the life of me figure out how to get the old one out???
Posted 30th Jul 2007 at 21:19
musclebeach
You don't need it fella, it must be used on the diesel models.
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 10th Apr 2010 at 18:05
