Author Subject: Speedo "ticking"
justinaccurate
Another "nev" thread im afraid Smile
I noticed something the other day I havent seen in a while
When I first got my car, when cold the speedo would "tick" around certain speeds. Instead of a smooth sweep, it jumped as you accelerated. It only seemed to happen around 60 mph before
It started happening again from time to time last week from 0-40.
Theres no difference in the performance, and everyhting still sounds fine Smile
Im guessing that the sensor it gets the speed from is needing a clean, but where is that?
Posted 7th Jun 2007 at 13:55
gazzerdaman
The speedo sensor is driven by a small plastic cog, this has prob lost a tooth. If not new sensor.
Gary
Cherry Red GTi 6
Posted 7th Jun 2007 at 16:57
cosmic spanner
Moral objector
Can anyone point me to its whereabouts on a parts CD/diagram, for a slice of dairylea? Unsure
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 7th Jun 2007 at 18:02
gazzerdaman
You have PM - diagram doesn't show location on box unfortunatly
Gary
Cherry Red GTi 6
Posted 7th Jun 2007 at 19:05
justinaccurate
Haha Gaz -why PM it? I need to know as well Smile
I assume its on the gearbox?
Posted 7th Jun 2007 at 19:16
gazzerdaman
Soz was where the picture was hosted. Give me 5 mins.
Yea its on the box
Gary
Cherry Red GTi 6
Posted 7th Jun 2007 at 19:17
gazzerdaman
Believe this is the part
I think its on the top of the 'box, can't remember off hand
Gary
Cherry Red GTi 6
Posted 7th Jun 2007 at 19:22
Rich E Forum Admin
Yeah, that's it.
The speedometer drive housing is bolted onto the offside of the diff casing. The large drive log locates into the output shaft on the diff and drives the control pinion which locates into the bottom of the sensor.
The sensor and control pinion can be inspected and replaced with minimal fuss, only requiring the gearbox to be drained. There is a single bolt that holds the sensor into the housing and the control pinion should come out with it.
You need to remove the driveshaft and speedometer housing to access the drive cog though.
Posted 7th Jun 2007 at 19:54
hybrid
can somebody tell me what is the name of this part?
and can i order it from ebay?
Uploaded with ImageShack.us
Posted 16th Jan 2011 at 00:28
smithers
According to servicebox it is called a 'Tachometer Screw'. There are 2 part numbers listed:
2643 04 19 DTS
2643 02 22 DTS
Both are priced around £5
I very much doubt that you will get one on Ebay Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 16th Jan 2011 at 01:23
hybrid
2643 04 19 DTS
2643 02 22 DTS
thanks so much! i will order it directly from peugeot!
Posted 16th Jan 2011 at 01:50
