Author Subject: key fob
krisbutler02
can some one tell me how to reprogram a phase 2 infared type 1 button keyfob thanks (i have used search function tno good though)
rallye mmmmmmmm
Posted 17th Apr 2007 at 00:35
the8valver
Do you mean reprogramme the infra red bit or the chip for the immobiliser?
If I see another six it'll be a fine day!
*edit, oh FFS or another Rallye*
Au Revoir T848UCHSad, gone but never forgottenBig grin!
Posted 17th Apr 2007 at 01:48
krisbutler02
the infared for the central locking
rallye mmmmmmmm
Posted 17th Apr 2007 at 01:49
the8valver
OK you need another key in the ignition turn it on two clicks then aim the blip key up at the sensor and hold it, it should catch the signal.
Do you have a manual it says how to do it in there, and to be honest I haven't looked at my manual just went by memory have a go then come back if it doesn't work, i'll dig my manual out.
Posted 17th Apr 2007 at 01:52
krisbutler02
i only have one key thats the problem lol
rallye mmmmmmmm
Posted 17th Apr 2007 at 01:53
the8valver
Try taking the blade out and using pliers on it, I'm sure I did this at some point, but check how far the blade goes in so that you can get it out again and or get purchase on it, then aim the blipper at the sensor.
Posted 17th Apr 2007 at 01:57
krisbutler02
ill have a go
rallye mmmmmmmm
krisbutler02
didnt work here is what i did
1 turned ignition on to pos 1
2 pointed ir at reciver for a few secs
3 turned ignition off
4 tryed fob ( didnt work
what am i doing wrong
rallye mmmmmmmm
Posted 17th Apr 2007 at 02:03
the8valver
Think it needs to be position 2, just going to get my manual hold on, you pest I have to get up now.
Posted 17th Apr 2007 at 02:06
krisbutler02
lol soz mate i cant find me manual cheers mate
rallye mmmmmmmm
the8valver
Only kiddin'
Taken directly from manual deffo for IR Ph 2, as that's what mine is.
The doors must be unlocked.
Use key without remote control (or in your case blade and pliers) to turn on the ignition to position A "accessories".
Place the remote control key within 4 inches of the receiver (located close to the interior mirror, for thickos, maybe you lol).
Press button 1 or 2 within 10 seconds of turning the ignition key. Edit you wont have button 2, GTi only.
Turn off ignition.
Test, repeat if necessary.
It will work it took me a few goes from what I remember.
Posted 17th Apr 2007 at 02:17
krisbutler02
rite ill give that a go
rallye mmmmmmmm
Posted 17th Apr 2007 at 02:16
krisbutler02
nope no joy with taht either Sad
rallye mmmmmmmm
Posted 17th Apr 2007 at 02:53
the8valver
You sure your remote has power, does the little red light come on when you press the button, maybe try new batteries in it, otherwise just keep trying.
Posted 17th Apr 2007 at 03:11
krisbutler02
yeah light lights up so is working ill try new batterys but surely it would work from 1cm away even if batterys were low?
rallye mmmmmmmm
Posted 17th Apr 2007 at 03:51
krisbutler02
rite decided to try my brothers key and ir box his works perfectly in my car but i cant seem to reprogram his to my box or mine to his box if u get what i mean so do i need a new key that is matched to the box or what?
rallye mmmmmmmm
Posted 26th May 2007 at 00:01
sixysix
Had to reprogram my keys today after batteries died.
Bit of arsing around but I found this works best.
It's more or less the same as what 8valver quoted from the handbook.
First off, no need for pliers and stuff, just seperate the fob so that you have your key blade in one half and your remote button plip in the other Wink
Insert key into ignition and turn 1 click so battery light comes on.
Place the remote control within 4 inches of the receiver,
within 10 seconds of turning the ignition key, Press button 1 or 2 (hold for 4-5 seconds, found this worked better).
Turn off ignition.
I had to program both remotes again. To do this is the same as the above exept the second key needs to be programmed within 10 seconds of the first key
To do this...
Grab second remote (dont need to take this one apart for the blade), then press and hold button 1 or 2 within 10 seconds or programming the first remote.
Turn off ignition.
If all's well, just pop the first remote back together and job done.
This did the trick for me and both remotes working as before Smile
Take a look
Posted 20th Jan 2010 at 20:46
