Author Subject: Brake Light Switch?
mullybaby
Was driving home earlier today and noticed my brake lights weren't working properly, they would only work every other couple of times, but after about one hour of driving they started working properly again. Is this to do with that little white switch on the brake pedal? If so, does anybody know the part number? Any help greatly appreciated as i can't drive the car until this is fixed Dry
Posted 19th Mar 2007 at 05:52
jim01uk
not sure on the part number, but they are only around £4 and a bas**rd to fit. mines off back to pug to have it replaced under warranty today, as i have broken the one they fitted last year. its just toooo tempting to stamp the M1155s on from high speed!
Posted 19th Mar 2007 at 12:43
mullybaby
Lucky ba*sstrd Happy
At least there cheap, plently of skin loss for me today then Roll eyes
Posted 19th Mar 2007 at 21:12
mullybaby
Just did this, plenty of small cuts on my hand now Dry Pretty straight forward job once you unbolt the steering rack Wink
Posted 19th Mar 2007 at 21:17
mystery_man11990
This was a right b*tch to do, but when I finally figured out how it popped out it was easy enough.
Tools:
A torch
A flat screwdriver
Firstly remove the fusebox panel to give yourself a bit more light if you dont have a high powered torch.
Remove the drivers heater and remove the panel just below with the dash dimmer and headlight dipper controls. The heater will come free with gentle force using the lower open panel to help you seperate the heater tube from the blower.
When thats done shine your torch down the cavity and your looking for a black cylinder shape with a white connector attached. That is the Brake light switch.
To remove the switch you physically need to be on your back in the footwell with your head under the dashboard. Use the torch to locate the white plunger which is located near the top of the brake pedal.
Just push the plunger through and pull the wire through the open drivers blower. disconnect it and replace or repair.
Refitting is the reverse of the above.
With my switch one of the connectors had oxidised. All I did was separate if from its housing, ground down the affected connectors and gave the spring a slight stretch. Reassembled and it works perfectly.
Total time: 30 Minutes
10 minutes to remove, repair and test. 20 minutes arsing about trying to get the bloody thing back in...
Big grin
Posted 13th Jun 2009 at 01:27
vts_tibi
thank god I have a Xsara! you don't even have to get under the dashboard! Reach down the brake pedal, find switch, pull out, remove plug!
refit the new one
job done! Big grin
mine just went out today! LOL
VTS
best 60' : 2.272
Team Trackday™
Posted 13th Jun 2009 at 02:37
smegal
Tools:
A torch
A flat screwdriver
Big grin
A VERY GOOD GUIDE! I started by wasting time unnecessarily dropping the steering column.
Ex SC-6
Now in a Megane R26
Posted 11th Jul 2009 at 19:32
justinaccurate
I think mine has died. I recently checked all my lights and had 1 fog and 1 side out. But the wife wasnt around so couldn't check the brakes. So I bought a load of bulbs (swapped the mains for nightbreakers) - then found that f*ck all happens when I pump the brakes Doh
Posted 10th Mar 2010 at 00:24
mabgti
NV motors
alot easier to do with column unboltedYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 10th Mar 2010 at 00:30
justinaccurate
Mysteryman's directions are spot on, apart from I needed to drill out a rivet on the blower pipe. I was going to make a guide with pics but there so few stages and you have to do most of it by feel its kinda pointless. Took me about an hour - 20 minutes to get the vent out, 5 minutes to get the switch out and 30 minutes to get the sod back in! 5 minutes to put everything else back.
Didnt unbolt the column, though I bet its easier to refit as you could then get your hand to the right position to push the switch back in and you could probably see what you were doing Smile
Posted 13th Mar 2010 at 15:41
smegal
I stand by that going through the vent is easier.
Ex SC-6
Now in a Megane R26
Posted 13th Mar 2010 at 15:49
alcon
I've just done mine and agree that removing the air vent and the panel below is the easiest way....not that it was an easy job. I also had to prise off a rivet in the blower pipe and then extract the pipe via the vent hole. The switch came out easily enough once I got my arm in there but trying to get the switch back through the hole was a bit of a headache. With my left hand up under the dash feeling about for the end of the switch and my right arm deep inside the dash, I suddenly felt it pop through and it was in! Everything else after that was quick. I too now look like I've been slashing my wrists!!
Not a job I want to repeat in a hurry.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 9th Aug 2014 at 14:06
matt16v
Can't figure out how you guys are getting the driver's side air vent out, think I'm going to give the column way a go.
1999 Astor Grey GTi-6 OEM+
Posted 2nd Dec 2014 at 11:00
alcon
Gently prise the vent off the dash using a flat bladed screwdriver. Just be careful not to damaged the dash obviously, but it should just pry out.
1999 Rallye (black)
Posted 2nd Dec 2014 at 11:03
matt16v
Did it! I see now the rivet you are on about, next to the relays. How did you manage to prise that off?
http://imgur.com/YBnN0Up - This one?
Posted 2nd Dec 2014 at 11:45
alcon
The rivet is fairly soft (aluminium IIRC?) so should just break off if your squash it with pliers and ease it out with your screwdriver. There's probably a better way of doing it but I just basically destroyed it until it fell out!
1999 Rallye (black)
Posted 2nd Dec 2014 at 13:25
jimmyhackers
i can confrim this job is a b%$tard....if my arms weren't as scrawny i doubt id of been able to fit them through the driver side air vent hole. few pointers for any other unfortunate soul.
my forearm at its widest (where it gets stuck) is about 30cm around, if yours are larger id imagine even more swearing.
a powerful torch to get a good view/picture in your head of the layout will help as youll be puting it in blind once your arms in there.
you can drill out the aluminum rivet holding in the blower pipe quite easily, ive replaced it with a plastic trim plug/clip when refitting (weight savings too Big grin )
there is a bare metal hole right next to the hole the switch goes in....ignore that one. it goes in a plastic holder right next to it further in.
there are relays infront of the concertinaed air pipe, you can remove one torque screw and this comes out of the way allowing more access to remove the pipe.
compared to the steering column out method, which i did to diagnose the faulty switch 2 days prior. the air vent method was far less hassle.
Posted 22nd Jan 2025 at 12:31
