Author Subject: Window Repair FAQ
sport1901966
I went through the hassle of my electric window doing something that sounded like exploding in the door. With a bit of effort I managed to fix it myself for very low cost.
Basically I thought I’d put up what I’ve learnt to help anyone who needs it.
Sorry I don’t have any pics of the process but I diid this a long while ago
What had happened to me was whilst I was moving the window the green runner shattered and the window fell off the guide bracket.
WARNING - If the window does fall and you hear a crunching sound, don't try to press the window switch anymore and the regulator may be still be useable!
Posted 31st Mar 2007 at 21:14
sport1901966
A picture of how it should look in the door
Posted 29th Feb 2008 at 05:13
sport1901966
The repair process was as follows:
1) Went to Peugeot and bought the mounting kit (only a couple of quid) which consisted of:
• Green Runner
• Gray Bung with spring clip
• Grey Plastic Guide Clip
NOTE: You may not have to do this if you can find one intact from a breakers
Posted 15th Jan 2007 at 01:18
sport1901966
2) As I needed to replace the Regulator motor because the cables had become out of sync and tangled (the Guide Bracket, Motor Cables and Regulator are all one unit) I went to the breakers and found one from another 3 door (any should do IIRC I think I used a P1 unit).
NOTE: Stay away from pug they charge obscene money for this part
3) Remove the door cards and old motor (I would describe this but it’s a while since I did the job so might not be accurate)
I believe there were 3 bolts holding the regulator and 2 more holding the guide bracket, will be rivets that need drilling if the unit hasn't been removed before.
4) Refit the new green runner into the bracket if needed (this I cannot remember in the slightest how to do)
5) Once everything is out including the window fix in the new motor in the words of Haynes ‘refitting is a reversal of removal’
Posted 15th Jan 2007 at 04:25
sport1901966
6) Now put the Grey Plastic Guide clip into the vertical rubber seal at the back end of the door. (The clip clips into the hole on the edge of the glass to guide it up and down the door.)
7) Slide the window into the door then push it onto the Guide Clip
sport1901966 has attached the following image:
Posted 15th Jan 2007 at 01:23
sport1901966
8) Then put the Grey Bung through the hole at the bottom of the glass from the inner side of the window.
9) The Green runner pushes through the Bung then the spring clip pushes through holes in the bung to hold it in place
10) Ensure the window is lined up with all the guides in the door and your good to go
sport1901966
Glad to help, if you run into any more intricate problems just post on here - it may well jog my memory back.
Good luck
Posted 15th Jan 2007 at 02:52
topshot_2k
Move to FAQ/Guide Section?
Owner of a Nile Phase 2 GTI-6 & Impreza WRX Smile.
Posted 15th Jan 2007 at 17:10
Welly Forum Admin
Top dog matey Thumbs up
Vrs power!!
Posted 18th Jan 2007 at 04:24
sport1901966
Get this FAQ'd??
Phil
Moved to FAQ Thumbs up
Posted 1st Apr 2007 at 02:51
This thread has been locked
