Author Subject: Key Battery Replacement FAQ
Please don't post on this thread!
ok nice easy one
if you are ph3 owner and the batery in the key seems to be dying try this 1st and don't let peugeot tell you it needs reprograming in because it doesn't!
Note i'm unfamiler with ph1-ph2 models so not sure if this applys!
1st buy one of these baterys
CR1620 £2.30 from GSF inc VAT
gnrlee has attached the following image:
Posted 26th Apr 2007 at 19:27
next
Remove any keyrings and the small Philips Screw from the back like so!
Posted 15th Nov 2006 at 21:38
now to prise appart
i found using the top the best bit!
Posted 15th Nov 2006 at 21:40
which should come appart like so..
Posted 15th Nov 2006 at 21:46
jim01uk
Yes it applies to P½ models, but anyone who cant figure out how to change the battery in a keyfob needs putting down!
Posted 15th Nov 2006 at 21:53
Then just put it back together and test it!
Job Done! Happy
FAQ Please Smile
Posted 15th Nov 2006 at 21:55
gazzerdaman
Warning, do not lose the piece highlighted in this photo - it is the transponder chip for the immobiliser.
Your car will not start with out it !
Also IIRC there is a notch in the keyfob to allow a screwdriver to be used to prise it apart
Good work mate Thumbs up
gazzerdaman has attached the following image:
Gary
Cherry Red GTi 6
Posted 15th Nov 2006 at 22:14
MS
formerly manny
How many of these CR1620 batteries are required for a P2 remote. Need to give the spare remote to my sis but it's got no batteries in it. I've got one battery here and it's not enough. So i'm not sure if i need new batteries (it looks like i'll need 3 Shock) or whether i need a different size of battery.
The last thing i want to do is put 3 in and blow the thing up by giving it 9 volts!
I could take apart the other remote but i'd rather not.
Posted 30th Mar 2007 at 04:54
Rich E Forum Admin
It should say in the handbook what battery you need. My phase 3 handbook actually says to use a CR2016, not CR1620 as stated above.
The CR sizes are the diameter and depth of the cell, so you could actually measure what size you need.
CR1620 = 16mm x 2.0mm
CR2016 = 20mm x 1.6mm
and so on...
Posted 30th Mar 2007 at 05:23
MS
formerly manny
Cheers Rich. Useful bit of info that. Thumbs up
Think best thing for me would be to just take apart my working remote and see what batteries are in that.
As some of the guys told me at the midlands meet, the P2s use a different alarm system to the P3s yeh?
Posted 30th Mar 2007 at 05:22
Rich E Forum Admin
Yes That's the best option.
The systems are essentially the same, just re-designed, and the fobs were switched from IR to RF.
Posted 30th Mar 2007 at 05:28
MS
formerly manny
Is that so??? Huh? Interesting. You telling me i could use an RF fob with mine if it was programmed?
I hate the crappy range of my IR one.
Posted 30th Mar 2007 at 05:31
Rich E Forum Admin
No Sadly not, no. I meant that feature wise they are essentially the same.
The alarm and immobiliser are seperate units on the phase 2 but combined into a single unit on the phase 3, which has the RF receiver built into it.
Posted 30th Mar 2007 at 05:44
This thread has been locked
