Author Subject: CV boot FAQ
Welly Forum Admin
PLEASE DO NOT POST HERE
Vrs power!!
Posted 4th Mar 2006 at 19:10
Welly Forum Admin
If your boot has gone a good sign is the inside of your rims looking like the inside of your underpants after a good night out.
Covered in greasy shite.
SO go to pug and buy a new boot kit containing a new boot,new grease, new clips and a new ring pieceWhistle
And some new Gearbox fluid
Welly has attached the following image:
Vrs power!!
Posted 4th Mar 2006 at 19:17
Welly Forum Admin
Next up get the car ready:
Jack the car up
Take the wheel off
Empty the gearbox fluid
Loosen the hub nut off by removing the pin and using a large socket
Drop the ball joint (17mm socket)
Vrs power!!
Posted 4th Mar 2006 at 19:16
Welly Forum Admin
Once the driveshaft is off the car, you will need to remove these 2 clips.
There a b*tch I warn you Geek
Vrs power!!
Posted 4th Mar 2006 at 19:18
Welly Forum Admin
Next up slip the top of the boot off and get your finger into the boot and pull as much of this evil Devil grease out.
It gets everywhere and i would wear gloves
Vrs power!!
Posted 4th Mar 2006 at 19:19
Welly Forum Admin
Once thats cleaned up slip it backwards to allow you to do the next bit.
You will need to tap the Joint off the splines.
It will come off but you will need to tap and turn, it needs to come off evenly.
so TAP AND TURN
Vrs power!!
Posted 4th Mar 2006 at 19:21
Welly Forum Admin
Eventualy it will come off, dont drop it as its bloody heavy.
Once off remove the boot and inspect the damage
Vrs power!!
Posted 4th Mar 2006 at 19:23
Welly Forum Admin
You will need to replace the ring that holds the joint in place.
You have one in your kit so replace it!!!!
Vrs power!!
Posted 4th Mar 2006 at 19:25
Welly Forum Admin
Next up offer the new boot in place.
Its easy if you slighty grease the shaft up..
Vrs power!!
Welly Forum Admin
Now you need to put the joint back on.
Best thing to do it to spin the nut back on, and hit it with a hammer till it goes over the ring.
The ring has a tendency to want to jump out so be carefull at first.
You can add a tie wrap to keep it under tension and when the joint moves into place just cut it off.
The nut will stop you from shagging the threads
Vrs power!!
Posted 4th Mar 2006 at 19:46
Welly Forum Admin
Now the messy bit
FILL it full of your new grease, its a good idea to stick the clip on at the bootom of the boot first though
Vrs power!!
Posted 4th Mar 2006 at 19:29
Welly Forum Admin
Talking of clips they are a tw4t to do.
I defy anyone not to swear whilst doing them.
Now add it to the car and put it all back Thumbs up
Vrs power!!
Posted 4th Mar 2006 at 19:30
black 6
This should be FAQ'd before it gets lost please Admin.
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 20th Mar 2006 at 11:26
LRV8
Sorry Welly- I'm happy for admin to delete this before they FAQ it but.... which clips did it come with and how the fook did you attach them?
Last one I did had the one you have to pinch it over itself, but it's so tight Angry
Ended up using a big jubilee!!
Nick
Ex P1 GTi 6 owner ... now P2 DTurbo
Cherised 6 gone Sad ... but now 580 miles per tank Smile
Cambelt FAQ Guide; Track Rod & Inner Balljoint; Modified Airbox; Alloy Anthracite Refurb; Induction Roar Tunnel Video
Posted 20th Mar 2006 at 11:53
black 6
The one Welly has is the genuine Pug one. You need a special tool to do the clips up. The CV boots from factors come with clips that you don't need tools for.
Posted 20th Mar 2006 at 12:12
This thread has been locked
