Author Subject: Lambda FAQ
Welly Forum Admin
Easy fix..
If your motor is running rich ( you can smell fuel in the exhuast)
Or its just running like a bag of spanners.
Replace the Lambda.
Not so easy to do due to it practicaly welding itself to the cat.
First up this is a lambda,
Welly has attached the following image:
Vrs power!!
Posted 17th Feb 2006 at 00:34
Welly Forum Admin
The is the business end of the probe.
DON'T TOUCH IT
Good ones also come with a squash washer
Vrs power!!
Posted 17th Feb 2006 at 00:37
Welly Forum Admin
Next up open the bonnet.
At the back of the bulkhead find the wires that run down to-wards the lambda.
There is a connection block that you will need to split.
Pull the red tab out and separate the 2 parts
Looks like this when undone
Vrs power!!
Posted 9th May 2007 at 05:49
Welly Forum Admin
I cant show you any pictures o this next bit as its impossible to take photos when your flat on your back with a car on youDry
You have to get under and locate the lambda, its to the rear of the subframe. At the front of the cat converter.
If you have disconnected the concter block CUT the plug off and grab a 22mm ring spanner.
Feed the wires through the RING end and Get a decent grip on the lambda and do your best Arnie impression to get the bugger off. You may need quite a bit of Wd4 and a scaffold tube.
Once off, replace with new one and tighten up.
Plug in and yer doneBig grin
Go for a blast and watch your wallet become fat again
Vrs power!!
Posted 17th Feb 2006 at 00:45
Welly Forum Admin
The problem they suffer is they get coked in soot.
Mine was knackered
The probe has small slits in to allow the gases to Roam over the senser.
These get clogged with soot and hamper the performance of the lambdaSad
Vrs power!!
Posted 17th Feb 2006 at 00:49
This thread has been locked
