Author Subject: Track Rod End How To
Welly Forum Admin
This is probably the easist yetBig grin
It really is simple,
The track rod ends basicaly are the bit between the hub assembly and the steering rack.
They have a pivit system on them and these can wear causing really bad feel for the road.
They are not expensive at all.
I would suggest changing these at the same time as lowering the car, makes a substantial differnce.
Both side cost £14
They are the same across the 306 range
Welly has attached the following image:
Vrs power!!
Posted 25th Jul 2005 at 22:16
Welly Forum Admin
First up you need to loosen this nut, Its a 16mm and is pretty tight
Vrs power!!
Posted 25th Jul 2005 at 22:19
Welly Forum Admin
Once that top nut is loose, Before you remove it all the way.
Loosen the lock nut, Its a 19mm spanner
Vrs power!!
Posted 25th Jul 2005 at 22:21
Welly Forum Admin
Next remove the nut at the top and tap the bolt with a hammer and it should fall through,
Holding the Track ROD still, unwind the track rod end counting the amount of turns it takes, They can be stiff to start with
Try to keep the ROD in the same place throughout
Vrs power!!
Posted 25th Jul 2005 at 22:32
Welly Forum Admin
Mine took 21 per side, but it could be anything.
You are trying to get the same posistion as near as damn it.
You will need to get it tracked regardless, but as close as you can so you can drive to the tracking centre.
Once on tighten up the lock nut and yer done,
Next up get it tracked.
Vrs power!!
Posted 25th Jul 2005 at 22:29
Welly Forum Admin
Tracking should cost around £20
If you can find a laser Tracking system that the one you want.
It should be around +2 -1.
Happy HuntingCool
Vrs power!!
Posted 25th Jul 2005 at 22:31
jon kirby
just 1 thing, there are flats on the end of the rack rod that you can use a spanner on if you don't fancy using maul grips Wink
Posted 25th Jul 2005 at 22:44
Welly Forum Admin
16mmWink
Vrs power!!
Posted 25th Jul 2005 at 23:21
fletch
Track Head
Any chance we can put this in the FAQ admin for easy access?
Posted 25th Aug 2005 at 10:59
Welly Forum Admin
Oh yes please
Vrs power!!
Posted 25th Aug 2005 at 11:09
mattyb
nice guide. Be warned tho, if you've got a high milage 306 (like mine where everything is seized), the track rod end will possibly incredibly hard to undo, but its possibly.
Made a massive difference to the way mine drove and got rid of a vibration under braking i had.
nice one.
2004 Civic Type R - 200bhp Weekend fun
1998 Civic Aerodeck VTi - 170bhp Practicality
Posted 31st Aug 2005 at 22:34
25guy
I know we're not supposed to post in this thread but...
Do they cost £14 each from Peugeot or GSF?
Just wondering,
Thanks
As clever as a man with 3 heads
Posted 8th Sep 2005 at 00:08
Boy Ward
one thing that i found that helped getting the top nut on and off was jacking the wishone up Yes
when i took one nut off it actually snapped it off the ball joint lower down and i ended up having to hacksaw it off on the thread to drop the ball joint out. was shitting it at first and then thought of the hacksaw.
does wonders for the steering and feel though, did mine at 56000 and had all 4 wheels tracked afterwards ... WOW, it turns in so much sharper now and the feel is better than ever (although i put some of that down to the new wishbones and bushes as well) Big grin
For Sale: Lower Glove Box From Rallye (incl hinge pin things) - £30 Delivered
Posted 8th Sep 2005 at 00:35
Welly Forum Admin
Just wondering,
Thanks
Local Factors
Vrs power!!
Posted 8th Sep 2005 at 00:43
seanpool-uk
Erm i had to hunt high and low for info on this, admins please move thread to FAQ!
Posted 8th Feb 2006 at 23:51
Welly Forum Admin
Yep agreed
Vrs power!!
Posted 8th Feb 2006 at 23:54
This thread has been locked
