displaying posts 26 to 40 of 40
Pages (2): 1 [2]
Author Subject: Gearbox?clutch
Welly Forum Admin
Next up remove the top mount, undo the big 19mm nut and washer.
Then the 2 3mm nuts either side and remove the rubber buffer, (its easier when putting the gearbox back on)
Welly has attached the following image:
Vrs power!!
Posted 24th May 2005 at 20:43
Welly Forum Admin
Next, let the gearbox down, slowly, it will rest on the bricks under the gearbox, and the axle stand
Be carefull as its a lot of weight
Vrs power!!
Posted 24th May 2005 at 20:56
Welly Forum Admin
Next remove the bell housing bolts, theres a few off them.
They are quite long, and a mixture of 17mm bolt, and 8mm hex bolts
This is what you are looking for
Vrs power!!
Posted 24th May 2005 at 21:07
Welly Forum Admin
Bolt No 1
17mm
Lower front
Vrs power!!
Posted 24th May 2005 at 21:08
Welly Forum Admin
Bolts 2 & 3
2 is 17mm
3 is 8mm hex and lower starter motor
Vrs power!!
Posted 24th May 2005 at 21:09
Welly Forum Admin
4 & 5
4 is 17mm and the upper left most
5 is a 8mm hex, and the last starter motor bolt
Vrs power!!
Posted 24th May 2005 at 21:10
Welly Forum Admin
Number 6
This will already be removed, its the bolt from the cover plate..
Vrs power!!
Posted 24th May 2005 at 21:12
Welly Forum Admin
Bolt 7
8mm hex, bit of a bugger to get at this one
Vrs power!!
Posted 24th May 2005 at 21:16
Welly Forum Admin
Bolts 9 & 10
both 8mm Hex, and facing the other way to the others
Vrs power!!
Posted 24th May 2005 at 21:18
Welly Forum Admin
Post #35
Once all the bolts are undone, its just a case of wiggling the box backwards and off..
If you keep the jack under the box, you can lower the jack all the way and reaching from the top, swing the box away...
Hey presto box off
BE CAREFULL of the aircon pipe at the bottom of the rad
Vrs power!!
Posted 24th May 2005 at 21:21
Welly Forum Admin
Post #36
To remove the clutch, you will need to undo 6 6mm hex bolts, that hold the cover plate in place.
Undo them evenly, as there is a lot of force in the coverplate.
Once off you can remove the clutch and see the fly wheel for all its gloryBig grin
Vrs power!!
Posted 24th May 2005 at 21:25
Welly Forum Admin
Post #37
While the box is off, gently rub the coverplate with some wet and dry to buff the surface up slighty.
And whilst the box is off, you might as well, grease up the fork ends
Remove the fork by pulling up and away
Vrs power!!
Posted 24th May 2005 at 21:35
Welly Forum Admin
Post #38
You wanna clean and grease this little dude up..Its the bottom of the fork
Vrs power!!
Posted 24th May 2005 at 21:37
Welly Forum Admin
Post #39
Thats about it...
When putting back together, grease the splines up on the gearbox shaft, it helps to allign the splines.
Use the same method when putting the box back on, lift the rear up on to a axle stand, and jack the front up and slide forward..
Again watch the rad and aircon pipes....
Vrs power!!
Posted 24th May 2005 at 21:43
Welly Forum Admin
Post #40
now bolt it all back together, Dont forget to fill up with oil (75/80) and take it steady for the first 100 milesBig grin Big grin
Vrs power!!
Posted 24th May 2005 at 21:45
Pages (2): 1 [2]
This thread has been locked
