Author Subject: Fog Light FAQ / Bumper removal
Welly Forum Admin
First off Remove both front wheels and put up on axle stands, This make life so much easier rather than struggling like a muppetWhistle
First off you will need to partly remove inner arch liner,
To do this remove the 2 screws at the bottom, These are Torx screws. (i have removed them already so you can see where they are)
Welly has attached the following image:
Vrs power!!
Posted 19th Mar 2005 at 15:42
Welly Forum Admin
Next off is the clips that hold the liner in,
Best to remove these by a bottle nosed pair of pliers, grab and pull
Vrs power!!
Posted 19th Mar 2005 at 15:43
Welly Forum Admin
Now you can get at the bumper mounts.
They are a b*tch to photograph whilst on the car so you will have to bear with me while i show you random photos with it on and off
Vrs power!!
Posted 19th Mar 2005 at 23:14
Welly Forum Admin
Ok, First easy mount is at the top of the bumper just under the wings, Its a big white rubber mount with a single 10mm head on it, All you need to do is loosen it off
Vrs power!!
Posted 19th Mar 2005 at 15:49
Welly Forum Admin
This mount is the easy one, All you do is slacken the bolt and the mount free's up and you can slide the whole thing off
You can see here where it slides
Vrs power!!
Posted 19th Mar 2005 at 15:51
Welly Forum Admin
This is the mount its self,
Vrs power!!
Posted 19th Mar 2005 at 15:52
Welly Forum Admin
Next up is the 2 bolts that hold the bumper to the front slam panel,
The passenger side are easily spotted,
The drivers you have to move the big loom out the way, You will see what i mean when your under there
This is the drivers side.
And the lower right nut, The other is on at the higher left corner
Vrs power!!
Posted 19th Mar 2005 at 23:15
Welly Forum Admin
Off the car you can see what i mean, These are both 10mm
Vrs power!!
Posted 19th Mar 2005 at 15:56
Welly Forum Admin
This puts in perspective where they are
Vrs power!!
Posted 19th Mar 2005 at 15:57
Welly Forum Admin
This is the Passsenger side higher nut, If you find the horn its up and right.
Vrs power!!
Posted 19th Mar 2005 at 15:58
Welly Forum Admin
Passenger side lower left,
Again find the horn and its on the left
Vrs power!!
Posted 19th Mar 2005 at 15:59
Welly Forum Admin
Next off, Unclip both fog light wires
Or in a minute you will pull them to piecesShock
Vrs power!!
Posted 19th Mar 2005 at 16:00
Welly Forum Admin
Next up is 3 10mm bolts across the bottom of the bumper.
These are the middle and left
Vrs power!!
Posted 19th Mar 2005 at 16:02
Welly Forum Admin
ET VOILABig grin Big grin
Just pull off Whistle
Vrs power!!
Posted 19th Mar 2005 at 16:04
Welly Forum Admin
Whilst off its onlt 3 8mm bolts to change the fogs and 5 mins to give the bumper a proper scrub
Its as easy to put back together as it is to take off
Thumbs up
Happy huntingCool
Vrs power!!
Posted 19th Mar 2005 at 16:07
This thread has been locked
