Author Subject: HandBrake adjustment
Welly Forum Admin
The handbrake isnt that hard to adjust, Its only a ten minute job and can be done by even the slightist skilled personWhistle
First off Pull the gear gaitor up and leave out the way
Welly has attached the following image:
Vrs power!!
Posted 20th Feb 2005 at 17:40
Welly Forum Admin
Next undo these two nuts..(10mm)
Vrs power!!
Posted 20th Feb 2005 at 17:41
Welly Forum Admin
Next pull out the rear tray, and undo these 2 fellas..(T20 torx bit)
Vrs power!!
Posted 20th Feb 2005 at 17:42
Welly Forum Admin
Right now pull the whole thing up, Should like this, its a tight pull up but should stay there nicely,
The centre cowling doesnt need to be removed as the bit you want is where the ratchet head isCool
Vrs power!!
Posted 20th Feb 2005 at 17:44
Welly Forum Admin
Now as im kind i DID remove the lot just to show you all whats lurking underneath
Vrs power!!
Posted 20th Feb 2005 at 17:46
Welly Forum Admin
Under the carpet flap there is this
Vrs power!!
Posted 20th Feb 2005 at 17:48
Welly Forum Admin
This is the nut you need to tighten (13mm)
Vrs power!!
Posted 20th Feb 2005 at 17:50
Welly Forum Admin
Now the only way to do this is with an extension bar and ratchet placed like so
Vrs power!!
Posted 20th Feb 2005 at 17:52
Welly Forum Admin
Now the quickest and easist way i found was:
Click the handbrake up 2 clicks, which should be when the switch is pressed and the light comes on.
Tighten the cable up, it doesnt need to be THAT tight,
To test just move the car forward and back alittle to see if its biting, then slacken off to whats needed
Clapping.
Now stick it all back together...
(Useless fact, I did this in reverse, i did it and thought Doh what a great FAQ)
Vrs power!!
Posted 20th Feb 2005 at 17:56
Clapping.
It's all that simple until it ceases and you need to get to the cable after it's left the underside of the car to the rear wheel as found out when MOT'ing a Rover that had ceased and whole cable needs to be replaced and exhaust needs to be moved ½ a day job really.
Posted 15th Mar 2005 at 23:02
stilly
i found that it woz easier 2 jack the back wheels off the ground 2 get the tension rite when doing the hand brake ..
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 10th Mar 2006 at 18:53
rhythmic
Careful not to overadjust this because it seems to pull on wires that run up to the centre console (they're not used on our 3 door cars but if shorted can cause problems!)
Great guide though, found it really helpful!
Posted 13th Mar 2006 at 15:39
This thread has been locked
