Author Subject: Brake Bleed How to
Welly Forum Admin
Ok strip the wheel off and get to this stage
If you dont know how to, read this
Here
Vrs power!!
Posted 9th Dec 2004 at 19:40
Welly Forum Admin
Right This is the Bleed nipple, underneath the cover is the brass bleed point...
Welly has attached the following image:
Vrs power!!
Posted 9th Dec 2004 at 19:41
Welly Forum Admin
Now pop the cover off and this is what it should look like, but most of the time cleaner
Vrs power!!
Posted 9th Dec 2004 at 19:42
Welly Forum Admin
This is a brake bleeding hose kit,
Its made up of 2 pipes although you only need one,
With a Non return valve one end
And a Flexible tube on the other
There is a reason why these are clear, its so you can see if there is any bubbles in the system, before the escape,
Handy if there is water in the system, you might need a good bleed through
Vrs power!!
Posted 9th Dec 2004 at 19:50
Welly Forum Admin
There are other Kits on the market,
The small orange hose kits cost next to nothing but are VERY messy and normaly to short for the job
Some "1 man kits" Attach to the spare wheel to use air to push the fluid through STAY WELL AWAY They are SHITE, air is the thing you are trying to eliminate,
That and 36psi into a brake resevoir tends to make them explodeCrazy
So be carefull when getting one, they are mega usefull if doing alot of work to the brakes
Vrs power!!
Posted 9th Dec 2004 at 19:53
Welly Forum Admin
Now the easy bit
Undo the fluid cap
Check that the fluid level is at MAX, if not top it up...
Undo the bleed nipple 1 turn, Thats all it needs
Now pump the peddle a few times, it should go all the way to the floor..
Now get out and check the pipe, to see if there is any bubbles in the pipe, if there is Pump again (remember to check the resevior)
If not tighten up the bleed nipple, and put every thing back togetherThumbs up
The white tab Will push down further, that holds the pipe on securly and will stop it popping off
Vrs power!!
Posted 9th Dec 2004 at 20:05
Welly Forum Admin
Now the serious bit
Brake Fluid Is VERY dangerous, dont get it on any paint work as its also a very good paint stripper..
If you do splash any, lots of water should do the trick..
If in doubt get a friend to help as an air bubble, even the smallest slightist bubble will be enough to stop the brakes working effectivlyShock Shock
Brake fluid for our cars should be Dot4..
There s no real need to go to any other spec fluid, unless you know what your doing,
In which case you wont be reading this
HAPPY HUNTINGThumbs up
Vrs power!!
Posted 9th Dec 2004 at 20:01
jimmy_boy
King
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 9th Dec 2004 at 20:02
dommorton Forum Admin
dude one small tip for one maning it
That white plastic tab actually pushes right down over the pipe and nipple to secure pipe tightly to nipple Wink
Posted 9th Dec 2004 at 20:04
This thread has been locked
