Author Subject: Brake Pad How to
Welly Forum Admin
Ok Back to Basics,
I will Try and guide the complete novice into changing front pads step by step
First Park up the car in a nice safe place away from kids.
Loosen wheel nuts so they are easily undone when wheel in the air
Welly has attached the following image:
Vrs power!!
Posted 9th Dec 2004 at 19:08
Welly Forum Admin
Now Jack the car up from the Proper jack point, Not the floor pan as you will bend the body
Once done try and get an axle stand under
Dont want the car coming down onto the discShock
Vrs power!!
Posted 9th Dec 2004 at 19:10
Welly Forum Admin
This is what you should Now be facing
Vrs power!!
Welly Forum Admin
Now you will Need a 13mm spanner and a 17mm Spanner..
First loosen the whole assembly by turning the 13mm spanner only, once that starts to spin, hold the 17mm and the undo the bolt
Dont take complety out untill both are finger tight, once out stick the bolts to one side
Vrs power!!
Posted 9th Dec 2004 at 19:13
Welly Forum Admin
You will now be able to wiggle the caliper off,
It may take a bit of wiggling but will pop off
Now is the best time to take the Wear sensors (Them 2 wires) out,
This is what it looks like
Dont stress the brake fluid pipe, the caliper will rest on the disc, but its best to get a welding rod, or a wire hanger, and hang the caliper off the spring
Vrs power!!
Posted 9th Dec 2004 at 19:17
Welly Forum Admin
This is what the piston looks like, Carefull with brakes dust you dont wanna be breathing that in..
Give it all a quick wipe round to get the shit out
Vrs power!!
Posted 11th Dec 2004 at 17:24
Welly Forum Admin
Now here is the clever part..
UNDO THE BRAKE RESEVOIR
This is the proper kit for the job, they cost less than a tenner and make the job MUCH easier,
You will need to push the piston back into place, if you are suck then a flat bar across the piston and a big screwdriver to push it will be ok, just dont deform the piston
Vrs power!!
Posted 9th Dec 2004 at 19:21
Welly Forum Admin
Now this Magical stuff is called Copperslip,
WHY
Cos its got copper in it, and its slipperyRazz
It has a very high melt point, and wont wash away like grease, its used to stop brake squel and you will find many a use for it.
Costs less than a fiver and will last for years
Vrs power!!
Posted 9th Dec 2004 at 19:23
Welly Forum Admin
Now im putting my old pads back in which is why they look warn, but this is all you need to do to stop new pads squelling
just aplly a small amount of copperslip like so
To the rear of the pad ONLY!!!
Vrs power!!
Posted 11th Dec 2004 at 17:23
Welly Forum Admin
Now when i say small i mean this much maximum
Both pads will need a smear
Vrs power!!
Posted 9th Dec 2004 at 19:27
Welly Forum Admin
Now do the reverse to put all back together...
Dont worry if the caliper moves backwards and forwards a bit, All you will need to do is press the brake a few times and it will move back into place
Sit back and admire
Vrs power!!
Posted 9th Dec 2004 at 19:29
Welly Forum Admin
Now you will need to do the same on the other side.
A few things to note
DONT put the new pad face down on the ground, it will get covered in dust and will scratch the disc
DO use thread lock on the bolts not to much though
DO tighten all bolts up as tight as they will go, And best check them after 50-60 miles
DO bleed the brakes while your there
DONT rag the brakes as they will need Bedding in for at LEAST 100 miles before they "key" To the disc properly, and will have full potential
HAPPY HUNTING PEEPSThumbs up
Vrs power!!
Posted 9th Dec 2004 at 19:32
This thread has been locked
