Author Subject: Vacum line - T piece help
Joka-cro
Can someone explain if that T piece after vacum pump is working like one way valve ? Because I am missing that piece, so need to do something alternative on .
Thank you
Posted 29th Sep 2026 at 09:36
it does, though you can bypass the T piece and run directly onto the vacuum pump and blank the intake port.
Posted 29th Sep 2026 at 17:49
Joka-cro
But when I blank the intake port engine is dieing on idle ....
Posted 29th Sep 2026 at 19:41
then you have a problem elsewhere.
Posted 8th Oct 2026 at 17:54
jimmyhackers
i have a feeling something has been lost to google translate here?
if you leave an open hole on your intake manifold....your engine will stall.
the best option is to source that t peice if you want things standard.
id suggest getting a blanking pate for removing your vacuum pump (spoox shop Sad ). and fitting a simple one way brake valve inbetween your inlet manifold vacuum line and the brake booster line.
or failing that welshpugs option of just plumbing the booster line into the vac pump is viable, but i would still add a one way brake valve in the line.
if for whatever reason you remove the brake booster line from the brass nipple on the inlet manifold, that open hole in the brass part will make the engine stall.....this is what you need to blank/block/cover.
if you introduce a hole to the manifold by removing the vacum line and it doesnt want to stall, there is a problem.....and if you cover the hole and it stalls then.....you also have a problem.
Posted 18th Oct 2026 at 09:17
Joka-cro
Brake booster has a original one way valve build in on his connection... Basicly I can add another one way valve between T piece and intake port but in which direction?
Thank you
Posted 18th Oct 2026 at 11:47
you dont need it, just block the port.
Posted 20th Oct 2026 at 10:12
