Can someone explain if that T piece after vacum pump is working like one way valve ? Because I am missing that piece, so need to do something alternative on .Thank you
| Author | Subject: Vacum line - T piece help |
Joka-cro
Newbie Location: Varazdin Registered: 07 Oct 2013 Posts: 35 Status: Offline |
Can someone explain if that T piece after vacum pump is working like one way valve ? Because I am missing that piece, so need to do something alternative on .Thank you |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
it does, though you can bypass the T piece and run directly onto the vacuum pump and blank the intake port.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Joka-cro
welshpug! wrote: it does, though you can bypass the T piece and run directly onto the vacuum pump and blank the intake port. But when I blank the intake port engine is dieing on idle .... |
